I've used a Sony DVD505 CAM before, which made mini DVDs, then I ripped into AVI files with DVDFab (by chapter), then edited using Pinnacle 12.
Now I'd like to move on to HD, so I've got a Sony CX550 and Pinnacle 14 HD. I would like to create HD files (not Blue-Ray disks) to play in Win Media Center.
Here are my questions:
1) I thought I'd see MKV in Pinnacle as the H.264 container, but I can't find it. What container is best to use ?
2) In Pinnacle they have what they just call MPEG4 which produces a MP4 file, but I can't see any option for 5.1 sound, just MP3 stereo up to 192kbps. How can you get 5.1 sound in a file to be played by Media Center ?
So what's the way to go if you'd like to have HD with 5.1 sound in files instead of disks ?
	If you are going down the H.264 route then MP4 or M2TS are probably the simplest containers. MP4 has the most support, but is more limited (i.e. not everyone supports AC3 audio in the MP4 container yet, for example). AAC can handle 5.1 channels, but most amps don't support it. Read my blog here.
	OK, thanks. The videos from the Sony CX550 come in the M2TS container, but how can I get Pinnacle to generate files (after editing) in that container ? ?
 http://www.kiva.org/about
  Free Way to create RM files???By John Kurtzke in forum Video ConversionReplies: 9Last Post: 20th Dec 2010, 23:15
  Here is how to create PS3 Compatible Files with 5.1 AudioBy pogues in forum MacReplies: 1Last Post: 5th Jan 2009, 01:30
  how do i create ifo etc filesBy gurunutkins in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 12:41
  How to create dat files?By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
  How do I create an MKV from AVI files?By cyber0ne in forum Video ConversionReplies: 3Last Post: 20th May 2007, 09:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
