I know that some part of the video file has higher bit rate than the rest and it could become real pain in the @ss when you want to convert the video file into another format without loosing quality and wasting file size.I've tried "mediainfo" software to show me the bit rate but it only showing me the beginning bit rate of the video.Is there any kind of freeware to see the highest bit rate or change format with out loosing quality or file size(would be nice with step by step guide)?
I'm trying to change flv to avi.
bitrate viewer to view the bitrate and peak bitrates
It depends on what kind of video & audio is in the flv (use mediainfo)
On some types, you can use flvextract and it will extract your flv to avi (with separate audio) , then avimuxgui to mux the audio in .
On other types you can use ffmpeg to switch containers
Some are not compatible with AVI and you would have to re-encode (lose quality)
Flash video to MPG-2: bit rate?
By am_dew in forum Video ConversionReplies: 6Last Post: 16th Sep 2011, 09:48 -
Help Reducing Bit Rate on video
By Aleahsmom in forum Video ConversionReplies: 2Last Post: 28th Apr 2011, 14:47 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
audio bit rate showing in video
By soulman1015 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 11:44 -
Which video format has the best about everything ( quality, bit rate...) !?
By coxanhvn in forum Newbie / General discussionsReplies: 17Last Post: 3rd Sep 2008, 22:02
