I have a Gateway desktop computer that's about 7 or so years old. I want to replace the DVD drive cuz it's been getting funky about playing Netflix DVDs.
I'm considering buying a new Lite-On IHAS22406 Internal DVD drive. It's also a burner which I don't care about but all new drives seem to be burners.
My question is will a Lite-On IHAS22406 DVD drive work in my old computer? If so, do I also need to get a SATA II 3Gbps cable with 4-pin Molex adapter?
Thanks.
It should work fine as drives do not really suck up any resources themselves.
And if you get a SATA drive and your PC does not have SATA connections then yes you would need to get the adapters and a SATA PCI card.
But it would be much easier and better to just get an IDE drive for a system that old.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007589%20600003705&IsNo...eId=1&name=IDE
$18.00 & up
Can anyone recommend any good general Internet / Computer Help Forums?
By jacknscoob in forum Newbie / General discussionsReplies: 10Last Post: 22nd Jan 2012, 05:38 -
Recommend a DVD player with USB/DivX Playback please...
By vonsworld in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Oct 2011, 12:17 -
recommend dvd player skips fbi warning
By joshua4 in forum Software PlayingReplies: 5Last Post: 24th Jun 2010, 01:43 -
Can anyone recommend me a new DVD player
By johnyccc in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Jan 2010, 20:13 -
Buying a new dvd player soon, please recommend one
By dimmy32 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Dec 2007, 12:57
