Hi, Im using the free DVD Video Converter by DVDVideoSoft to rip a DVD and although I find this software super easy to use and Im using the highest quality setting to produce an .AVI....I am getting horizontal lines during motion sequences... (is this called "combing"?). This makes my files unuseable for presentation.
Is there anything I can use to fix this on the .AVI that was produced? Or...I am also open to using other software if better results will be achieved (such as quality that will match the DVD).
I have Premiere Pro CS5...is there anything I can do with that to help?
Looking forward to your suggestions, and finding something that works, as I have many of my stage performances on DVD that I need to convert to files.
Thanks!
Results 1 to 30 of 40
Any special reason to stick with AVI ? ( check this : http://en.wikipedia.org/wiki/Audio_Video_Interleave )
If you can live with MKV check out makeMKV or Handbrake.
Makemkv ( free for now ) rips the main program directly from DVD but does not transcode ( output = mpeg2 and selected audio + subtitles )
Handbrake ( open source ) requires a DVD access tool ( some are free also ) , transcodes to mpeg4 or h.264 and has plenty of audio/video/subtitles settings including some advanced deinterlace and decomb filters.Periculum in mora -
These programs are so complicated! I've been playing with video for years but now I feel like a newbie! I dont think MKV will be a good format for me. If my intent is to take a portion of a DVD, and NOT edit it, Im guessing I would want to make an MPG H.264? And if I want to edit it, same? But if I want to keep a high-res archive file of what I ripped, wouldnt I want to use AVI?
You might try out XviD4PSP, it's fairly easy to use. It can convert a decrypted DVD VIDEO_TS file to a MKV file with a fairly small file size and not much loss in quality. MKV is a much more advanced codec than Xvid/Divx for compression. You might try it.
Almost no highly compressed format is good for editing, Xvid, Divx, H.264 included. You want to do that in a less compressed format most times.
But if you just want to convert a DVD main movie to a archive file, H.264 does very well.
Quick and easy with XviD4PSP, pick 'DVD', find the decrypted VIDEO_TS folder and use 'x264 Q21 HQ Film' video settings and use 'Copy' for the audio settings and see how it looks.
Other settings may work better, depending on your PC capabilities. -
If you want simple uncompressed copy of DVD in a future proof container makemkv is the way to go ( and free for the time being ).
The interface is very simple :
- put the DVD in a drive
- have MKV analyze it
- select chapters and audio
- hit the "make MKV " button.
Both video and audio are copied "as is" , just wrapped into an MKV container.
Further processing if needed can be done with one of the many other tools already mentioned here.
Periculum in mora -
Is there any advantage to ripping to MKV rather than just VOBs?
Also, are all VOBs extracting programs equal in terms of the end quality of the VOBs? For instance, if I rip to VOB using DVDDecrypter, will I get the same quality as if I rip using DVD Fab? It would be nice to know that for that step, all softwares are created equal... -
A VOB is just a MPEG with some extras.
(Subs, menus, alternate audio and languages, etc.) If you extract the MPEG, all extraction programs should do it equally. I usually use VOB2MPG, but I have AnyDVD running in the background to take care of decryption. They all just 'remove' the MPEG hiding in the VOB container.
The advantage to using the MKV format for me is small filesize. A 700MB MPEG-2 can often be reduced to ~400MB with little quality loss. You can't 'rip' to MKV, you need to encode to that format. -
Nope.
You have to remove copy protection (aka decrypt), and DVD Decrypter fails against modern copy protection - It hasn't been updated in a few years.
If these are your own home made "stage performance" DVD's then chances are they don't have advanced protection, but if they are retail DVD's and recent within a few years, there is a good chance DVD Decrypter will fail
If you see combing in your premiere sequence, then either your DVD was telecined from a film source , or your sequence settings were set incorrectly. Premiere can handle interlaced footage, but not telecined footage -
yes , and it's normal
if it's interlaced, you can activate a deinterlacer in your playback software for example
normal TV's and DVD players do this automatically , and they take care of normal telecine as well
if you are doing this for editing, you should leave it interlaced, but remove telecine (because most editors can't handle telecine) -
I guess Im used to playing back my ripped MPGs on PC to see if there is any combing BEFORE I begin assembling a montage in Premiere. Are you suggesting that maybe I skip this step and just go do the montage in Premiere because by playing with the sequence settings I will be able to "fix" the combing problem?
playing it back on a pc media player provides no information - the software might be ivtcing or deinterlacing on the fly
you need to use the correct sequence settings, or everything you export will have a problem
you would export as interlaced for dvd, and deinterlace for web export. Notice all this is done in the export stage, you don't change the sequence settings
this all assumes your dvd was interlaced , not telecined. If it was telecined, you would IVTC (inverse telecine) ,and everything would be progressive (sequence settings, export settings) -
Thanks so much poisondeathray! Your explanation is clear.
I just have a few more question.
- If you are NOT planning on editing the footage you ripped, should you still bring it into Premiere just so that you get rid of the combing thru the export process?
- And does this mean that the playback on the PC (ie. iTunes or Windows Media Player) will then be "fixed" and without the combing effect?
- How would I know if something is telecined? For instance if I ordered an instructional DVD from the USA, would it be telecined or are only motion pictures telecined?
1) you don't have to use premiere , you could use any number of programs, but you first have to figure out if it's interlaced or telecined
2) yes you can "fix" it. But if you deinterlace , you can bob deinterlace or single rate deinterlace. 60i footage is 59.94 fields per second, or 29.97 frames per second . When you deinterlace you throw out half that information, and motion is a lot choppier (30 vs. 60) . If you bob deinterlace you can make it 60p, but DVD-video doesn't support 60p only 60i . Avi files if played on PC could be kept interlaced , or bob deinterlaced to 60p , or single rate deinterlaced to 30p - you can do anything if your goal is PC
And if it was telecined, and you inverse telecined, it would return the progressive frames
DVD-video doesn't support anything natively progressive. 24p is in 60i (that's what telecine is). You need that 60i signal to be NTSC DVD compliant.
Deinterlacing degrades quality, and the high quality filters take a long,long time to process . You only deinterlace if you have to (e.g. for web)
3) instructional dvd will likely be interlaced , not telecined. Movies shot on film have a film rate of 24p (e.g. hollywood movies) . Instructional video will be shot as video likely, not film , but there are exceptions.
To determine if something is interlaced or telecined , I use avisynth and examine individual fields (not frames)
http://neuron2.net/faq.html -
Ooh lala, that AVISynth looks complicated! I suppose I could instead experiment with different sequence settings in Premiere until I figure out if Im dealing with interlaced footage? Is AVISynth really worth the learning curve if Im pressed for time?
BTW, what would NOT be shot interlaced?
Do modern consumer camcorders shoot interlaced or deinterlaced?
Is deinterlaced same thing as progressive?
Does HD have anything to do with interlaced/deinterlaced?
THanks. -
you can do whatever you want , you might be able to fiddle with the settings and get it rightOoh lala, that AVISynth looks complicated! I suppose I could instead experiment with different sequence settings in Premiere until I figure out if Im dealing with interlaced footage? Is AVISynth really worth the learning curve if Im pressed for time?
it will be faster than taking a couple hours to learn the avisynth basics ... but then again it sounds to me you are new at using premiere too...
If you want to learn the proper way, eventually you will have to examine fields. You can't do that in premiere
Modern consumer camcorders shoot interlaced, and their "24p" mode is 24p in 60i or telecined. Only "prosumer" and "pro" camcorders and DSLR's shoot native progressive
If you have interlaced footage and you deinterlace it, the result is progressive. But remember deinterlacing degrades quality - and if you don't do it properly you throw out 1/2 the information, and most programs use very poor quality deinterlacers. The high quality ones are very slow to process, but the quality is much better (and of course they are avisynth based)
HD has nothing to do with interlace/progressive/telecined . You can have SD or HD and one of those. HD refers to the frame size , height > 576 pixels.
Premiere will separate fields when you look at the preview (just like a media player would deinterlace on the fly), so it's not representative of what you really have either. You have to use the proper sequence settings and export settings or you will get poor resultsLast edited by poisondeathray; 15th Sep 2010 at 23:48.
Not new....just super rusty!
Are you saying that Premiere will do a crappy job at deinterlacing? Would the average person notice this or just someone like you who is an expert in this and can "see" subtle loss of quality? I think I've deinterlaced in Vegas Pro and Premiere before and I didnt think that the footage had degraded that much....
Wow! Are you saying that the Preview window in Premiere is not even representative of what you will get once you export? (So it will be of no value whatsoever when determining if there will be combing in the final output?) -
Both vegas and premiere are garbage at deinterlacing. Do a search , many people have posted comparisons at this forum and many others . I've posted several myself
CS5 is slightly improved, if you use MRQ, but it's still slightly worse than an "average" avisynth deinterlacer
It depends on what you settings are for sequence and export. It's only valuable if you know what it means or how to use premiere. Even if it shows no combing, you can get combing on the export . An example of this if you use wrong export settings
You have to understand how premiere works and what the preview is actually showing you. You have to understand fields vs. frames . This is critical.
If you have interlaced footage (like the majority of consumer camcorder footage) , and you are looking at the preview, it won't show combing or those lines, because you are looking at a separated field. It separates the fields, because you can't edit in field mode. You have to look at full frames. If you export interlaced (like you would for DVD) , you won't see the combing , unless you watch on a progressive display (you will be seeing 2 fields offset) , but you would just activate a deinterlacer if this was on a computer. 100% of blu-ray and dvd players will play it without seeing the combing
Deinterlacing when you shouldn't is even worse, you will end up with jaggy lines and horrbile quality. There are many examples of that too , when people use premiere incorrectly -
If you're going to rip and convert NTSC DVDs, it might be worth understanding the difference between hard and soft telecine.
The link below gives quite a good explanation.
http://trac.handbrake.fr/wiki/Telecine -
You really need to create interlaced DVDs if the video is interlaced or telecined. Yeah, you can IVTC, but for home projects, that may be more trouble than it's worth.
This would take more time to explain than I have available.
Poison's giving you some good info. So good luck!Want my help? Ask here! (not via PM!)
If I understand correctly, its best to rip a DVD to VOBs on the hard drive, then convert to MPG-2, and then to examine the fields to see if deinterlacing is required, correct? (DVDDecrypter --> VOB2MPG --> AVISynth)
So programs like Xillisoft DVD Ripper are therefore useless with their apparent ability to go directly from DVD to AVI or MP4 or MPG? Because they skip the step of deinterlacing...which makes them more prone to creating rips that contain combing effect...is this correct? -
I would use dvdfab or anydvd . Dvddecrypter hasn't been updated in a few years and may fail with some copy protections
I don't know what xilisoft does, but it has a pretty poor reputation around here
If you want something easy to use , but better than xilisoft, try autogk for xvid/avi , or handbrake, or xvid4psp - they can make errors too, but are less prone.
The best way is to examine it manually looking at the field pattern - because no autodetection scheme is 100% perfect. Only human eyes can get it correct. -
Lots of people talk about using AnyDVD IN CONJUNCTION WITH DVDDecrypter or CloneDVD but really, you can use AnyDVD on its own to rip, correct? Why would people need to use it conjunction with anything else?
Yes, anydvd just works in the background. You can use it with other programs . But you might want functionality of other programs - maybe some people wanted to rip in IFO mode for example, for individual titles. You can just as easily use it alone and copy the whole disc
OK, so I ripped the DVD to my PC as VOBs (using AnyDVD by itself because there was no encryption), and I plan to edit various scenes in Premiere by adding graphics, titles, color filters, etc.
I will be exporting for Web, DVD, and perhaps iPhone.
My question is...
Now that I have VOBs on my hard drive, and considering that I want to work with the best quality source files in Premiere (which I will export to a number of media such as DVD, Web, etc), what file format should I convert the VOBs into? 2 years ago it was MPG2.
Is MPG2 still the best format to work with in Premiere to edit with least compression or would it now be better as MP4? Or something else I am not aware of?
Problem with motion getting jagged lines
By philflo in forum Video ConversionReplies: 2Last Post: 6th Mar 2012, 09:27 -
DVD ripped subtitle file conversion
By dbarrett in forum DVD RippingReplies: 2Last Post: 17th Sep 2010, 12:55 -
Conversion issues with with 1. vob-file of a ripped dvd
By NSmooch in forum Video ConversionReplies: 5Last Post: 8th Jan 2010, 02:55 -
Problems with "Motion Lines" in SOME ISO to AVI conversions using
By cplevel42 in forum DVD RippingReplies: 8Last Post: 8th Oct 2009, 18:30 -
I recoded my VOBs to AVIs, now I have like 'motion lines' thru the video??
By lrfowler in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2007, 20:43
