  1. My first attempt, hope someone can tell me what I'm doing wrong.
    I have an m2v file, an ac3 file and Celltimes.txt, extracted
    from my DVD with PGCdemux. The PGC component has 12
    chapters and Celltimes.txt looks like this:
    9180
    17940
    28830
    34170
    43890
    54090
    63300
    79620
    84300
    98430
    105975
    Attempting to put it back together with MuxMan, I specify the
    m2v and ac3 in the Video/Audio boxes respectively.
    I then use File->Import Chapter and load Celltimes.txt
    Hitting "Start" MuxMan duly creates a VIDEO_TS folder with VOB etc.
    However if I play this video, it has only a single chapter corresponding
    to the first track (song actually) on my DVD. Judging by size, the full
    video is there, but that is how it plays.
    Same result for playback using both VLC and Roxio player.
    Someone please help! Thanks.
    Dec 2005
    Canada
    On the bottom-left of the MuxMan window, does it show the number of "scenes" on the button - and if you click the scenes button does it list the times.
  3. The button is labelled 12 scenes and when pressed shows
    data similar to your picture, except that in the last column
    there is only one entry:
    Dec 2005
    Canada
    The MuxMan log file (in c:\) should list the chapter cells similar to the times shown in my image (and missing from yours).
    If the list is not present I can only assume it's something to do with the .m2v file - perhaps 'manono' can respond with further suggestions.
  5. Thanks for taking a look sambat.
    I checked the log and there were no scenes listed.
    But now this morning behaviour is different, and I have
    not a clue why this should be.
    The lone entry in that final column of the Segement Scene List
    has disappeared so the entire colum is blank, however this
    has caused the chapter breaks to be properly inserted!
    Correspondingly there is some scene information in c:\muxman.log
    Now I feel like a time-waster but cannot explain how it has changed.
    If anyone knows what is going on I would be keen to learn.
    Anyhow it seems to be resolved now, hope it stays that way.
    The muxman.log hint is handy - cheers.
