I have Nero 7 on my laptop, and normally burn TDK DVD-R. I happened to pick up a +R package, and decided to use it today. Nero objected. It suggested another DVD, =/-R/ RW type. Is there some way to tell Nero that my +R are fine? Maybe that happens during install. BTW, I had used a -R on the first copy w/o any trouble.
You'd be much better off using ImgBurn, but if you insist on using Nero, you might also try updating the firmware on your burner. Unless this burner is really old it's unlikely that it doesn't support +R discs. It could be that you need a newer firmware so that Nero can understand how to write to the discs. Having to update your firmware just to burn a disc is a sure sign of low quality media though. This not necessary with high quality media (Taiyo Yuden and Verbatim). ImgBurn may have a write strategy for the discs that does not require a firmware upgrade, so that's one of the many reasons we suggest it.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning Videos to DVD with Nero 9
By GeneYuss in forum Authoring (DVD)Replies: 6Last Post: 22nd Dec 2008, 07:11 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 02:11 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 14:15 -
Nero dvd burning, disabled?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 13:55
