As stated, whenever I try and use an .avi format (irregardless of codec) it always uses some random wierd default audio format- varies depending on the codec I'm trying to use but almost always listed as something strange. For instance, what I'm trying to work in is the x264 codec, so I- File->render as Save As Type->Video for Windows (.avi) Template->Custom (set my video settings; x264vfw) Audio Tab->(all the fields start off blank-white) Audio Format->Lame mp3 (44,100, 320kbs, cbr, stereo) When I click "ok" the description of this new template lists "audio: 40,000 Hz, Mono, 0x0". If I go back into the template and the audio tab, again all the fields are blank-white. This happens with every codec I try and use in .avi format, although the "random defaults" numbers changes, the fact that I can't set my own audio settings (or, they don't "stick" anyway) holds true. Any ideas? I'm running WinXP Pro SP3, Vegas 9.0, I have K-lite codec mega pack with option 7 (everything+player).
	I'll bet there's your problem.
 My various installs of Vegas have never had that problem, but I don't add All-in-One codec packs. They're well known to wreak havoc with systems.
 Start clean. Install ONLY what you need, when you need it, using the legit codec source.
  AVI audio becomes out of sync in Vegas Pro 9.0By Thunderhead2772 in forum EditingReplies: 5Last Post: 25th Nov 2011, 18:39
  Using a dual monitor set up in Sony Vegas 7By fuzzblaster in forum Software PlayingReplies: 9Last Post: 28th Sep 2010, 08:16
  bitrate lower than set when VBR rendering in Vegas 8By gtmb in forum Video ConversionReplies: 2Last Post: 29th Sep 2008, 08:02
  Converting a mov format to avi in Vegas 6.0By solarblast in forum Newbie / General discussionsReplies: 10Last Post: 25th Sep 2007, 11:29
  Audio Sync Problem Joining 2 AVI's Together from a 2 DVD SetBy boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 02:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
