hello
can you please tell me:
what is the full life-cycle of a video file that is sitting on [any server] and ends up being streamed-to / viewed by the consumer?
for example, this company show its architecture:http://www.pandastream.com/arch
it seems to me all they are doing is running FFmpeg + FFserver and charging 99 a month for it. (like a zillion others are now) .. am I correct?
this company show a server solution that I don't fully understand but it looks like a good approach: http://erlyvideo.org/files
I also have a AWS cloudfront account that I can not figure out how to stream from, but I assume I would be just as well off doing it from my own server if configured right
what do I have to do (on the front end and back-end ---360 degrees ) to set up this for my own site so that i can do multi protocol encoding and (ultimately) playback/streaming on any device using video tag
i could do the encoding locally and then stream from server it if that saves alot of expense and hassle, I'm not talking about live video...i talking about setting up a VOD website that works on web + mobile
please let me know what you think / if you can help
Setting up a video site is beyond me, sorry.
Yes, see these previous posts. (1) Will ffmpegX work in Snow Leopard? (2) 10.6 Snow Leopard compatibility (3) How to install ffmpegX on 10.6 without Rosetta?
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 22:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
