Hello!
I have recently taken some footage of a steam railway, on my Canon mvx25i, taken in 16:9 mode.
Played back on the camera it is fine.
When I edit it, if I render as an avi (DV DVD) the picture is not full screen but the action is smooth, and crisp.
However if I edit as an Mpeg (DVD Widescreen) the resulting acton is jerky, the video doesn't freeze but the movement is not smooth, and the focus is slightly soft.
I am using Ulead VideoStudioe SE DVD, however I have tried the trial versions of Corel VideoStudio X3, Corel Videostudio 2010 Express, Sony Vegas HD9+ pro, Adobe Elements 8 and Videopad.
These all seem to give the same results to varying degrees.
I am not burning to dvd, but steaming to the tv via a Zyxel DMA1000.
Any ides as to a fix would be helpful.
offhand, it sounds like your fields are getting reversed...
Canon mvx25i is a PAL MiniDV model. Video capture should be via IEEE-1394 interface to a DV-AVI file.
By "not full screen", do you mean letterbox?
"resulting acton is jerky, the video doesn't freeze but the movement is not smooth"
This sounds like a field order reversal in the project and/or encoder settings.
DV format is lower field first. Both the project and DVD MPeg2 encoder should be set to lower field first.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
ed,
Thanks for the reply!
What I mean by not full screen is not letterbox, the picture actually sits inthe middle of the screen with a black border all round.
I will check for field reversals though, and post the results.
Cheers. -
Perhaps your editor captured the DV stream in 4:3 project. That would letterbox it, with black bars as part of the imported video. When played on a 16:9 screen, additional pillarboxing would be applied to the sides.
Try if your editor allows for setting it to 16:9 before importing the original video. -
Yep, sounds like a 4:3 instead of DV Wide project setting, then a Wide export. That gets you four black borders.
In the second case there is a field reversal.Recommends: Kiva.org - Loans that change lives.
Video Action Tracking or Following
By Not_Sure in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 17th Jun 2016, 07:26 -
fast action blurs
By johnsees in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2008, 00:23 -
Help with sports action shooting
By cobra jet in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2008, 15:52 -
Custom DVD Action
By marioval in forum Authoring (DVD)Replies: 7Last Post: 11th Jan 2008, 09:05 -
Jerky action shots or panning motion
By dadrab in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:58
