It this file MPG, MP4, MKV or DV AVI?
As the resolution is 720x480 "Standard Definition" (fixed size) and probably 16:9, the content has to be stretched to fill that area.
This is quite common: DVD, digital television and DV cameras all do this.
The idea here is that movie pixels do not have to be square. A pixel that is 1.2 times wider than tall is perfectly fine (pixel aspect ratio = 1.2). When applied to a 720x480 grid, this PAR nicely fills out a 16:9 rectangle, like 853x480 in square monitor pixels.
(example illustration) -
The media file can tell the player what shape to display the picture. The displayed size doesn't have to match the frame dimensions. Make sure MPC is set to respect aspect ratio flags:
View -> Video Frame -> Keep Aspect Ratio
View -> Video Frame -> Override Aspect Ratio -> Default.Last edited by jagabo; 23rd Aug 2010 at 07:46.
By MGadAllah in forum EditingReplies: 3Last Post: 24th Sep 2011, 23:48 -
File Sizes
By rhodellf in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2009, 12:51 -
Joining 3 AVI's. Having trouble with video sizes. AVIDEMUX
By UmmAddan in forum EditingReplies: 4Last Post: 27th Feb 2008, 23:03 -
Betacam SP Sizes
By The Sumerian in forum MediaReplies: 2Last Post: 9th Sep 2007, 13:02
