I'm trying to put my copy of family guy on my PSP the trouble is that each episode seems to be in with another VOB file. Like dvd episode 1 will be in VOB 1 but the end of it will be in VOB 2 where episode 2 starts is there anyway to extract the episode?
I want to convert it with ripbot later on for my PSP.
Software such as DVD rip cant extract the right episode, i will get episode 1 but it will be missing the end.
Then you aren't doing it correctly.
The DVD format stores titles in Video TitleSets (VTS). Within titles are chapters. A titleset may require one or more VOB files (up to a maximum of 9 per titleset). A VOB file may not exceed 1000MB in size. Therefore any title may require a part of a single VOB, or multiple VOBs, depending on the size. All of this is described in the IFO files.
Depending on a how a disc has been edited/encoded/authored, multiple episodes may reside in a single title, which may span several VOBs. This makes it harder to extract a single episode because it isn't a title, but a set of chapters within a title.
If you rip the entire disc correctly, then open it in DVD Shrink, you will see all the titles available on the disc. In Re-Author mode you can shift titles from the right-hand side to the left-hand side to create a new structure with just these titles in it (but no menus). If you find that there is only a single title then you may have to trim it down to just the parts you want. To do this, drag the title to the left-hand pane, then right-click on the title and you will get an option to select the start and end points for that title. Use this to isolate just the section you want.Read my blog here.
You haven't said how long each episode is supposed to be. It is also possible, depending on how the disc was authored, for Shrink to show each episode as being listed more than once. Again though, if you go into Re-Author mode, you can drag a single episode across to the left and create a disc with just that episode. From there you can convert it.
Read my blog here.
There's probably an option to play all episodes in the DVD's menu. DVD Shrink would read that as duplicating the episodes. It's a half hour show so 21-24 minutes would be the normal length without commercials. The first five the individual episodes and the second five are the same episodes repeated because of the play all option.
Ripping a multi-episode DVD
By scoopyx in forum Newbie / General discussionsReplies: 5Last Post: 21st Dec 2009, 22:55 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 11:42 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32 -
how do i see hole movie with out stoping for new file..
By DenverJeepMan in forum Authoring (DVD)Replies: 6Last Post: 6th Dec 2007, 17:51 -
Ripping one TV Show DVD Episode into ONE File
By ronhammond71 in forum DVD RippingReplies: 11Last Post: 5th Jun 2007, 10:42
