Hello,
I have a m2ts ripped from a BD that has 1080p24 VC1 with AC3 5.1 audio.
What I wanna do is mux the video stream to a WMV container while converting the audio to either WMA 2.0 or 5.1 for XBox playback.
I was able to convert it to ASF without AC3 track using solveing muxer. How can I mux the audio in ? what to use to convert to wma?
I also tried WMNicEnc that seems should do it for the audio but I don't get any "codecs" in both audio and video option even if I have WMV codecs. I tried to install the codecs exe from the developer page but it seems corrupted? It says I don't have enough space on every machine I tried.
Anyway does it allow to mux audio and video while keeping the video without re compressing?
You can use windows media stream editor . There are lots of ways to convert to wma, eg expression encoder, wmnicenc, dbpoweramp etc... . You can check this thread, it lists the steps of what you want to do for xbox . You can start near the end near page 5 or 6.
http://forum.doom9.org/showthread.php?t=119785&page=6
Nope . It only accepts avs scripts, which means uncompressed audio & video once it's fed through avisynth. So requires re-encodingI also tried WMNicEnc that seems should do it for the audio but I don't get any "codecs" in both audio and video option even if I have WMV codecs. I tried to install the codecs exe from the developer page but it seems corrupted? It says I don't have enough space on every machine I tried.
Is it possible to take VC1 & convert DTS-HD to WMA Pro 5.1 and mux to WMV?
By bobthegoat2001 in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Dec 2011, 11:12 -
VC1 + (Patched) DTS + WMV on PS3?
By ecsjr in forum Newbie / General discussionsReplies: 3Last Post: 27th Feb 2010, 10:02 -
CLI to WMV/VC1? (WMV3)
By RogerTango in forum Video ConversionReplies: 11Last Post: 9th Nov 2009, 23:02 -
How i add subtitles to a vc1 wmv video?
By yigal33 in forum DVD RippingReplies: 1Last Post: 29th Dec 2007, 15:55 -
By yigal33 in forum SubtitleReplies: 0Last Post: 29th Dec 2007, 15:19
