hi,
It is a long ago since i was been searching for a tool (even not free) able to convert a .ts video.
A guy told me that my .ts is not just a TS but a protected one. But i can play it on every computer, so i doubt from his words..
Here the code's information.
Maybe you can help me, i hope so.
thanks
Code:I:\_a encoder\Babyfather (live 2010 Leno) HD720.ts General #1 ID : 1 Complete name : I:\_a encoder\Babyfather.ts Format : MPEG-TS File size : 461 MiB Duration : 4mn 46s Overall bit rate : 13.5 Mbps Video #33 ID : 33 (0x21) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, Matrix : Default Duration : 4mn 46s Bit rate mode : Variable Bit rate : 12.2 Mbps Nominal bit rate : 65.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.196 Stream size : 415 MiB (90%) Audio #36 ID : 36 (0x24) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 4mn 46s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : -605ms Stream size : 13.1 MiB (3%) Text #33-608-1 ID : 33 (0x21)608-1 Menu ID : 1 (0x1) Format : EIA-608 Duration : 4mn 46s MuxingMode : MPEG Video / EIA-708 MuxingMode_MoreInfo : Muxed in Video #1 Text #33-608-0 ID : 33 (0x21)608-0 Menu ID : 1 (0x1) Format : EIA-608 Duration : 4mn 46s MuxingMode : MPEG Video / EIA-708 MuxingMode_MoreInfo : Muxed in Video #1 Text #33-2 ID : 33 (0x21)2 Menu ID : 1 (0x1) Format : EIA-708 Duration : 4mn 46s MuxingMode : MPEG Video / EIA-708 MuxingMode_MoreInfo : Muxed in Video #1
also what are you trying to convert to? If you are trying to make a dvd try avstodvd or multiavchd.
If you want to convert to portable format for a handheld player try format factory or super.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thank for your reply.
i tried Handbrake and told me :
No Title(s) founds.
Your source may be protected, badly mastered or in a format which Handbrake does not support.
Please refer to the documentation and FAQ (see Help Menu).
The file (...) is of an unknown or unsupported file type.
Unsupported fiel type
Divx Converter does not support this type. Please make sure the input video is a supported input for DivX converter.
Error 22
Oh by the way, i am under Windows7 x64.
any idea ?Last edited by Michael REMY; 22nd Aug 2010 at 09:30. Reason: add and fix syntaxe
Virtualdub is one program. Have you tried using avisynth before opening the file? There is a drop down in the open window in virtualdub. Select avisynth then select the file - it should work.
Also try the other programs mentioned for converting.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
well ,finaly i successed !
i did it with updating divx to divx converter plus 8.0.1.49. Previous version i had was 7.x.
thanks all you guys.
Convert .exe video tutorials(built by Screencam) to video format
By cyforex in forum Video ConversionReplies: 3Last Post: 1st Apr 2012, 16:11 -
Convert video in BYGB format
By radler12 in forum Video ConversionReplies: 1Last Post: 21st Aug 2011, 10:22 -
MD video file format - how can I convert it?
By bahjan in forum Video ConversionReplies: 6Last Post: 20th Apr 2010, 08:05 -
How to convert video format of a video made on iMovie on a mac?
By squeejiboo in forum MacReplies: 1Last Post: 30th Jun 2008, 06:47 -
Software to manage video files for playback.
By lordhutt in forum ComputerReplies: 12Last Post: 23rd Jul 2007, 16:37
