  1. hey i was wondering whats the best software to burn raw mpgs with? i was useing convertxotodvd before. but that re encodes the video file... i dont want any re encodeing done when burning off mpgs
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVD-compliant MPEG files do not get re-encoded when authored to a DVD. Is that what you are talking about?....Authoring?
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    If you have a player that can play mpg files than use imgburn.
    If as hech54 asked you need it to be dvd compliant and author than only dvd compliant files will work. It has to convert if its not in dvd spec for a dvd player to recognize it as a dvd video.
    https://www.videohelp.com/dvd
    That is the list of dvd specifications. If it doesn't meet those criteria it must be reencoded so it will work properly as a dvd.
    Otherwise if you don't want to reconvert use a harddrive based player like a wdtv that can play just about anything without additional conversion.
  4. yeah im talking about authoring.. when i trans my tapes to pc with my wintv150 the file is a mpg... so when i burning off with convertxtodvd its re encodeing the video
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    dvd-lab or a free software like guifordvdauthor, muxman, dvdauthorgui. THey do no reconvert.
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just make sure you are using the dvd mode profile on the wintv. It still needs to be captured in the correct format to avoid reencoding. if it is not using one of the dvd presets than any software will be forced to reencode to make it compatible.
