im using lsx mpeg to encode the video file and when i burn the film it comes up in ful screen instead of widescreen any help with this?
You don't give a lot of info, but if you are converting a divx that are cropped to widescreen, then you should select the option "keep aspect ratio". Are you using the standalone or the plugin? If you use the plugin with FlaskMpeg i know you get the option "keep aspect ratio", if you use the standalone i don't know. Not familiar with that one. Anyway.. if you select "keep aspect ratio" you'll get the black bars on the top and bottom...
Good luck...
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
