  1. Hi all,
    I have installed the reallib files in the /Library/Application Support/ffmpegx/ folder
    But i still cannot convert RMVB files to MP4 files...
    Here is the log...
    FIXME:Hardenabling SSE and SSE2 without detection
    Sun Aug 22 14:18:45 SGT 2010
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    CPU: Intel  (Family: 6, Stepping: 6)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    success: format: 0  data: 0x0 - 0x946cfd3
    REAL file format detected.
    Stream description: Audio Stream
    Stream mimetype: audio/x-pn-realaudio
    Stream description: Video Stream
    Stream mimetype: video/x-pn-realvideo
    Stream mimetype: logical-fileinfo
    VIDEO:  [RV40]  512x360  24bpp  25.000 fps    0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:11  fourcc:0x30345652  size:512x360  fps:25.00  ftime:=0.0400
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=480 h=272]
    Opening video filter: [pp=0x33]
    Opening video filter: [harddup]
    Opening video decoder: [realvid] RealVideo decoder
    Read the RealVideo section of the DOCS!
    VDecoder init failed :(
    Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
    VDec: vo config request - 512 x 360 (preferred colorspace: Planar I420)
    [PP] Using external postprocessing filter, max q = 6.
    VDec: using Planar I420 as output csp (no 0)
    Movie-Aspect is 1.42:1 - prescaling to correct movie aspect.
    SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using MMX2
    Something went wrong, no index chunk found on given address (155610785)
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): no suitable image found.  Did find:
    	/Library/Application Support/ffmpegX/reallib/drvc.so: unknown file type, first eight bytes: 0x7F 0x45 0x4C 0x46 0x01 0x01 0x01 0x00
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
    x264 [info]: using SAR=272/337
    x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
    1 duplicate frame(s)!
    bad packet len (0)
    bad packet len (0)
    bad packet len (0)
    and it would keep "bad packet len (0)" all the way...
    It seems that mplayer can play the file (i pressed "Play" on the ffmpegx window)... so what can be the problem?
    Other things i've tried...
    1) remove all asian characters from the file names - doesnt work (same problem)
    2) change permissions for all the files in the /Library/Application Support/ffmpegx/ folder to read only - doesn't work
    3) change permissions for all the files in the /Library/Application Support/ffmpegx/reallib/ folder to read, write (after i changed to read only) - doesn't work
    4) invert the audio - doesn't work
    I am sure i DL'ed the right files for my computer (file name got Intel)
    Here's what i get when i ls that folder... seems ok right?
    My-MacBook:~ user$ ls /Library/Application\ Support/ffmpegX/reallib/
    AvidQTAVUICodec.qtx		msms001.vwp
    BeHereiVideo.qtx		msscds32.ax
    CLRVIDDC.DLL			nsrt2432.acm
    CtWbJpg.DLL			qpeg32.dll
    DECVW_32.DLL			qtmlClient.dll
    Essential Codecs Package.pkg	raac.bundle
    LCMW2.dll			rt32dcmp.dll
    LCODCCMW2E.dll			rv10.bundle
    QuickTime.qts			rv20.bundle
    QuickTimeEssentials.qtx		rv30.bundle
    QuickTimeInternetExtras.qtx	rv40.bundle
    README				sipr.bundle
    VDODEC32.dll			sipr.so.6.0
    ViVD2.dll			tm20dec.ax
    acelpdec.ax			tokf.so.6.0
    alf2cd.acm			tokr.so.6.0
    aslcodec_dshow.dll		tvqdec.dll
    atrac3.acm			vdowave.drv
    atrc.bundle			vid_3ivX.xa
    atrc.so.6.0			vivog723.acm
    clrviddd.dll			vmnc.dll
    colorcvt.bundle			voxmsdec.ax
    cook.bundle			vp4vfw.dll
    cook.so				vp5vfw.dll
    drv1.bundle			vp6vfw.dll
    drv2.bundle			vp7vfw.dll
    drvc.bundle			vssh264.dll
    drvc.so				vssh264core.dll
    dspr.so.6.0			vssh264dec.dll
    iac25_32.ax			vsshdsd.dll
    icmw_32.dll			vsslight.dll
    FYI i'm using the macbook white...
    What else can i do?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    The mencoder log seems to detect a framerate of 25 fps. Can you verify this in RealPlayer? Techniques like variable framerate can throw ffmpegX off when it looks at the first framerate number it finds.
    If ffmpegX can play the file through mplayer, then you have installed the reallib folder correctly.
    The "invert mapping" of the audio has no effect on mplayer/mencoder, as it is an ffmpeg option.
    For some conversions, RMVB files convert better when their suffix is renamed to ".rm"
    "bad packet len (0)" is –as I understand it– usually a sign of some form of data corruption in the source file. Could this be a captured network stream, like a file dump from a streaming server?
    Despite all the errors, did it generate an output file? Was it really (no pun intended) bad?
  3. hmmm.. my bad.. seems like the source file itself was corrupted.. only the first few min was ok.. so when i previewed the file i still could play it.. haha..
    thanks for all your help!
