Closed Thread
    May 2007
    I went to compress a video i captured of some tv footage, and it was HUGE! A 13gb file! I shortened it to 7gb with rejig, but there is no audio. How do i include the audio in the compressed file? Thanks!
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Some guides via the Wayback Machine here:
    http://web.archive.org/web/20041017054114/http://www.rejig.org/
    When you compressed the video (to M2V), presumably using "file mode", it should also have demuxed the audio (AC3) into the same folder. If so, you can use its "DVD author" mode to combine these into a new DVD fileset.
    May 2007
    hi! Thanks very much for the help!
    May 2007
    The weird part about this is, there is NO audio from the combined (mutiplexed) file. I compressed the original file into my c: root drive. I then demuxed the audio portion, putting it also in C: Then i went into DVD author mode, and tried to multiplex them, but there is zero audio. I wonder what i did wrong.
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    What do you mean "zero audio"?
    Is there an AC3 file?
    Can you play that alone?
    May 2007
    nope. There is NO AC3 file. Is it supposed to automatically created when the compressed file is? Do i click on "re-compress job" or "re-compress all"? Maybe "re-compress all" would create the ac3 file, too, where "re-compress job" will not?
    canada
    Please do not open another thread about the same subject,this thread is closed,just use your newer thread from now on.
