I am looking to author a DVD from video files which have L/R tracks so that they will appear as 2 different audio tracks on the DVD. This is essentially a karaoke dvd. Is it possible? And will the audio tracks be in mono or stereo?
It is possible. The results will be mon, although you can create two channel mono if you wish.
Essentially what you need to do is load the original audio track, copy the left channel over the right channel to replace it, then save this as track one. Load the original audio track again, copy the right over the left to replace it, then save this new track as track two. You now have two new tracks in place of the original L/R track. You can encode and author with these instead of the originalRead my blog here.
You can easily do this in Audacity (version 1.3 with ffmpeg plugin).
Open the audio file (Audacity can also directly open audio in many video files).
When it shows the track (stereo, l&r), left-click on the name of the track and choose "split stereo to mono".
Then you can save each track separately.
Audacity can save directly to AC3 for DVD.
The tracks will be mono; identical sound will come out of both speakers.
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 14:14 -
Video with 2 audio tracks
By mjaeson in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2010, 06:27 -
Unwanted Dolby Sound Mixed In With 2 Channel Stereo Tracks.
By travelagent73 in forum AudioReplies: 0Last Post: 18th Aug 2009, 11:49 -
Why are audio tracks of videos one channel only instead of 2?
By PunkMaister in forum Capturing and VCRReplies: 5Last Post: 18th Nov 2008, 18:34 -
how to: add 2 mono tracks = 2 channel wave?
By spiritgumm in forum AudioReplies: 4Last Post: 7th Sep 2007, 17:52
