    Feb 2009
    Estonia
    There is a film made by a YT user. I want to DL the parts and join them into one big whole. I don't want to re-encode. All the parts are 480p FLV except one that is 360p MP4. I used a filter to resize the clip to 720x480 (MPEG4 AVC x264). I can join them with Avidemux - copy streams. It successfully saves the file, but when I play it in the VLC it crashes when it gets to the resized part.
    I thought it's because I use different bitrate than YT, but those 480p FLVs also have different bitrate (used MediaInfo) but they are joined and played back without problems.
    Is there any way to do it by re-encoding just this one and not everything?
    Here are the clips:
    480p - http://www.youtube.com/watch?v=NVVVxWbLBbo
    360p - http://www.youtube.com/watch?v=7tEH2KeaUzs
  2. Aren't the 480p ones 640x480? If so, why did you resize the 360p one (480x360) to 720x480? Check the dimensions in GSpot or MediaInfo and resize to the same as the others.
    Feb 2009
    Estonia
    Nope. I guess 480p is something different. I guess 720x480NTSC and 720x576PAL are both considered as 480p. I may be wrong tho...
    Anyway. They are 720x480. Avidemux does not let you append a different frame size. That's how I discovered one was off in the first place.
  4. Oh yeah, you're right. Then the guy should either have resized to 640x480 or had the YouTube player do it by sticking in the right tag. Anyway, I don't know why they don't join, or what you did differently when you reencoded. Perhaps if you post the MediaInfo for both someone will spot an important difference.
    Feb 2009
    Estonia
    Here's the one from joined clips. I joined them and copied streams into MP4 container. This is the unchanged one:
    Format : MPEG-4
    Format_Profile : Base Media
    CodecID : isom
    FileSize/String : 249 MiB
    Duration/String : 41mn 58s
    OverallBitRate/String : 830 Kbps
    Movie : Conspiritus Remake Full 1-4.mp4
    Performer : Avidemux
    Encoded_Application : Lavf52.39.2
    Video
    ID/String : 1
    Format : AVC
    Format_Profile : Main@L3.0
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 3 frames
    CodecID : avc1
    CodecID/Info : Advanced Video Coding
    BitRate_Mode/String : Variable
    BitRate/String : 728 Kbps
    Width/String : 720 pixels
    Height/String : 480 pixels
    DisplayAspectRatio/String : 3:2
    FrameRate_Mode/String : Constant
    FrameRate/String : 29.918 fps
    FrameRate_Original/String : 29.917 fps
    Standard : NTSC
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 0.070
    StreamSize/String : 219 MiB (88%)
    Audio
    ID/String : 2
    Format : AAC
    Format_Version : Version 4
    Format_Profile : LC
    Format_Settings_SBR/String : No
    CodecID : 40
    Duration/String : 41mn 57s
    BitRate/String : 96.0 Kbps
    Channel(s)/String : 2 channels
    ChannelPositions : Front: L R
    SamplingRate/String : 44.1 KHz
    StreamSize/String : 28.8 MiB (12%)
    And here's the info from resized one:
    Format : MPEG-4
    CodecID : isom
    FileSize/String : 118 MiB
    Duration/String : 7mn 19s
    OverallBitRate/String : 2259 Kbps
    Movie : Conspiritus Remake part 5.mp4
    Video
    ID/String : 1
    Format : AVC
    Format_Profile : High@L3.0
    Format_Settings_RefFrames/String : 3 frame2
    CodecID : avc1
    BitRate_Mode/String : VBR
    BitRate/String : 2158 Kbps
    Width/String : 720 pixel3
    Height/String : 480 pixel3
    FrameRate_Mode/String : CFR
    FrameRate/String : 29.531 fps3
    Standard : NTSC
    ColorSpace : YUV
    BitDepth/String : 8 bit3
    Bits-(Pixel*Frame) : 0.211
    StreamSize/String : 113 MiB (96%)
    Audio
    ID/String : 2
    Format : AAC
    Format_Profile : LC
    CodecID : 40
    BitRate/String : 93.7 Kbps
    Channel(s)/String : 2 channel2
    StreamSize/String : 4.91 MiB (4%)
  6. Your framerates are bizzarre . It reports CFR, but the value is non-standard. Even if it's off by 0.0000000001 , it won't join
    Feb 2009
    Estonia
    That is funny because I have joined other clips into two big junks. One of them has fps 29.917 and the other one 29.918. They join and play back without problems. I tried to set the fps of that re-encoded clip to both values but the player still crashes everytime I use that clip.
    Must be something more.
    Feb 2009
    Estonia
    I tried to copy the streams to MKV container and use MKVtoolnix to mux them with correct FPS. This is teh error message I got: "The codec's private data does not match (lengths: 39 and 37). Please make sure that the resulting file plays correctly the whole time.".
    Any ideas what that means?
