I bought a Canon Vixia HF M30 and I shot on it all summer making a documentary for the camp I worked at. This meant that I transferred the files onto my hard drive since I have a lot of footage and they are currently in .mts files. I have no idea how to make this compatible with final cut express 4 or what I need to do. Do I need to get a converter? Any help would be much appreciated!
http://www.kiva.org/about -
Final Cut Express doesn't actually edit AVCHD, it imports it and converts it to Apple Intermediate Codec, which is a much more editing friendly HD supporting codec. AIC takes a lot more space then AVCHD.
Final Cut will only handle AVCHD files when it finds them in their original file structure (either by connecting the camcorder or using a memory card reader), not isolated .mts files.
In Final Cut you would open your log and transfer window and import the footage as AIC.
converting from mpeg2 or wmv to a format for idvd or final cut express
By jbrown23 in forum ffmpegX general discussionReplies: 2Last Post: 8th Mar 2011, 21:23 -
MTS and Final Cut / Adobe CS4
By jovannig in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jan 2010, 12:58 -
How to import MTS files in Final Cut Pro 6?
By Benhermies in forum MacReplies: 1Last Post: 11th Sep 2009, 02:32 -
AVCHD viceo with .MTS ending cannot be read by Quicktime/ final cut express
By johsch in forum ffmpegX general discussionReplies: 10Last Post: 26th Nov 2008, 14:01 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
