I recently bought a pinnacle PCTV Rave card, and found that I couldn't capture higher than 352x288 with VirtulDub, I know that it uses the BT878 chip and though it could capture higher than that 352x288.
Is there some 3rd party drivers that can help me???
Results 1 to 10 of 10
You must unmark overlay or/and preview in capture settings.
If you hav a big enough cpu you can capture full reslutionm,
using Vdub or avi_io.
dilbert -
so does this mean the captured video from a PCTV rave and a DC10+ are equivalent?
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 08:10 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 14:38 -
How to convert DVD to mkv with 720P or higher resolution
By dharmesh13 in forum DVD RippingReplies: 2Last Post: 21st Apr 2009, 20:47 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38
