I muxed 720p MKV to AVCHD and it allmost works on PS3(subtitle,sound and video works), but the problem is that when I start playing the movie, there is large black bar in bottom, about 1/3 of the screen. If I only open the mt2s from stream folder, then there is no black bar but also no subtitles(because it only contains movie+audio) . What is causing this problem?
Hi,
what´s the resolution of your video-stream ? If it does not match the AVCHD specifications (720x480, 1280x720 and 1920x1080) then the PS3 will move the pic to top of screen keeping a black bar at bottom with size of the difference between 720 and the height of your stream.
Nasty but there is no other solution than uncropping your video to allowed size.
Regards
KivasFajo -
it was 1280 x 536
Do you know what could be the fastest way do that? If there is a fast way..
Hi,
fritzi93 is right. uncropMKV is the only tool worth to be used.
Fast ? Depends on your machine and encoder settings - u have to re-encode the whole video stream.
U can also use the complete suite for this : multiAVCHD which includes the uncrop part.
If u download some stream
next time keep an eye on the resolution if u want to use AVCHD
Regards
KivasFajo
AVCHD to tsmuxer to watch on bluray-occasional 1 sec pauses
By jbitakis in forum Blu-ray RippingReplies: 2Last Post: 13th Nov 2011, 22:20 -
How i can make multi avchd dvd single layer discs with tsmuxer?
By fits79 in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Nov 2011, 08:09 -
Video Pixelation Converting MKV To AVCHD Using TSMUXER
By uscstyle in forum Video ConversionReplies: 26Last Post: 1st Apr 2011, 19:29 -
Subtitles stay too long when converting MKV to AVCHD for PS3 with tsMuxer
By WFlits in forum Video ConversionReplies: 5Last Post: 31st Oct 2010, 05:15 -
Problem with tsMuxeR...
By hiimbored in forum Authoring (Blu-ray)Replies: 8Last Post: 6th Oct 2009, 03:43
