  1. Hi, I've imported some WMV (AVI) video files into Adobe Premiere Pro 7.0, and when i put the files on the sequence there is no audio playback. There is also no display on the waveform. However in the preview box for the files imported in the project the audio plays perfectly. The files have 16 bit mono 32000 Hz audio, with the the video running at 15 fps.
    I don't why this isn't working so if you can help I would greatly appreciate it, thank you.
  2. Not sure why , if the preview works, then it should work when placed on the sequence
    For a temporary workaround, you could save it as wave and import the audio separately e.g. you could use virtualdub
  3. Thanks for your response poisondeathray, I tried VirtualDub but it didn't work, I got the file type wrong on the files I was speaking of. They are Windows Media Audio/Video files, not AVI. VirtualDub is calling them ASF files. Could this be the problem with Premiere?
  4. what does mediainfo say about the files?
    asf is essentially the same thing as wmv
    you can still use vdub with the wmv plugin
  5. MediaInfo gave the following:
    HTML Code:
    General
    Format                           : Windows Media
    File size                        : 271 KiB
    Duration                         : 8s 281ms
    Overall bit rate mode            : Variable
    Overall bit rate                 : 268 Kbps
    Maximum Overall bit rate         : 1 767 Kbps
    Video
    Format                           : WMV2
    Codec ID                         : WMV2
    Codec ID/Info                    : Windows Media Video 8
    Description of the codec         : Windows Media Video V8
    Duration                         : 8s 267ms
    Bit rate mode                    : Variable
    Bit rate                         : 354 Kbps
    Width                            : 640 pixels
    Height                           : 360 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 15.000 fps
    Bit depth                        : 8 bits
    Bits/(Pixel*Frame)               : 0.102
    Stream size                      : 357 KiB
    Language                         : English (GB)
    Audio
    Format                           : WMA
    Format version                   : Version 2
    Codec ID                         : 161
    Codec ID/Info                    : Windows Media Audio
    Description of the codec         : Windows Media Audio 9.2 -  20 kbps, 32 kHz, mono (A/V) 1-pass CBR
    Duration                         : 8s 281ms
    Bit rate mode                    : Constant
    Bit rate                         : 1 411.2 Kbps
    Channel(s)                       : 1 channel
    Sampling rate                    : 32.0 KHz
    Bit depth                        : 16 bits
    Stream size                      : 1.39 MiB
    I converted the audio of one video to MP3 using Adobe Audition and that worked fine, but you can't batch process videos and I have quite a lot of files. I haven't found a filter for VDub yet, does this convert both the audio and the video?
  6. well if you have a lot of them to do, I'm not sure if vdub is the best solution . Vdub can convert audio & video, but if the video isn't a problem, there is no reason to do that (lose quality if you use some lossy format) . The problem is you'd be doing it one at a time. While you can batch convert with vdub, it's pretty a "clunky" way to do it
    mp3 probably isn't a good idea either, unless you don't care about the quality loss
    you probably want to do a batch conversion . You could probably do it with ffmpeg with a .bat file , or use a gui for it like winff
    you also might consider upgrading, because newer versions of premiere do not have issues with wmv such as the one you have there
  7. Thanks a lot for your help
