OK....here's the scoop.
I sent a friend in Oz a DVD(of a VHS tape she sent to me to digitize). Now she wants this stuff on her iPhone. I've experimented on getting her "there" with freeware....all worked out well using WinFF with 640x480 res.(sent her a 30 second test clip). It's my understanding that WinFF needs ffmpeg for it to function....but I don't recall ever knowingly installing ffmpeg on my system. I suppose I got ffmpeg via SUPER or some other program somehow?
Anyway. What programs do I need to have her find, download and install so I can call her and talk her through the process? All I want her to do (besides rip the disc BY CHAPTER with DVDDecrypter - but I've got that covered) is to drag the 36 chapters of this disc into WinFF - change the res to 640x480 (MPEG4 - MP4 Fullscreen), hit CONVERT and go have a cup of coffee, or two....or three.
It all works well for me....but I'm not 100% sure what I'm actually using here.
Thanks in advance for any tips.
H.264 is the codec identifier and the compression method used. X.264 is an encoder that implements H.264 compression. ffmpeg is another encoder that can do H.264 encoding.
From what I have seen, most front-ends, such as WinFF, bring the required libraries with them. So WinFF most likely installed a version of ffmpeg when it was installed. SUPER likewise. It is possible to have several different versions of ffmpeg installed on your PC at the same time. Audacity Beta uses a different version again, DVD Flick installs one. Many of these front-ends will only work with the version of ffmpeg they install, and cannot work with a newer version (or older version) without being re-compiled.
If she installs WinFF, she should get the appropriate version of ffmpeg installed at the same time.Read my blog here.
Read my blog here.
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 14:22 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 15:13 -
Mov h264 to MP4/h264 Conversion
By Scooter_NJ in forum Video ConversionReplies: 2Last Post: 26th Mar 2009, 11:07 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
