I have followed the guide to converting to VCD. When i get to the part that says "first select file> preview to view what the video will look like I get a black screen. Even after starting the conversion process for awhile and stopping, and trying to preview its still a blank screen.
I get the same thing. I've worked on it for two day and can't figure it out.I know it's gonna be something simple. If you find the answner please let me know. THX :D
I had the same thing happen. Go to tools on the left side of this web site then look for codecs find NIMO and download it. After install you should be able to view the movie in TMPEnc. Well at least it worked for me. Post back if it solved the problem.
Good Luck!! -
Certy, make a few adjustments and it worked. I just had to play with it. Thanks so much.
TMGEnc Xpress - no sound
By deanst2 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jun 2010, 17:27 -
TMGEnc Xpress Not enough memory issue
By hawk123 in forum Video ConversionReplies: 0Last Post: 10th May 2010, 18:21 -
burning errors in nero & tmgenc dvd3
By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 11:23 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 13:19 -
Tmgenc DVD Author
By powerkoala in forum Video ConversionReplies: 10Last Post: 19th Sep 2007, 06:02
Sorry, it didn't work for me. But thanks for your suggestion.
