I have some anime i wanna burn onto a DVD+R but some of them are differnet formats (MP4,MKV and Avi). Do i just use imageburn or do i need to do something before. Since i know that Avi files will not be converted to video in image burn.
I have nero8 but it seems that it doesnt accept MKV's. I just wanna burn anime and watch it on my dvd player
If your dvd player doesn't support mp4 and mkv you must convert to dvd-video, with for example dvd flick or convertxtodvd.
Or if your dvd player supports avi divx/xvid files you could convert all other video files to avi divx/xvid with for example xmedia recode and then burn all avi files with imgburn. You can fit more minutes/dvd with good quality if you choose avi instead of dvd-video. -
Only video playing programs on the computer will handle all the different codecs you are loading onto disc. A few newer DVD players will handle Divx/Xvid and MPEG-4. but it is not all that common. You will most likely need a DVD-compliant disc, which requires conversion.
So, follow Baldrick's advice. -
uhh its a chinese brand. 步步高DVD player HD901 . uhh think its bbk dvd player hd 901 in english
Burning MKV Files
By PHNeedsHelp in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Mar 2012, 09:59 -
Burning files on DVDs
By carlmart in forum ComputerReplies: 3Last Post: 23rd Sep 2011, 10:46 -
Mutiple (30+) AVI's to DVD; DVD plays only the first 15
By sudiptoghosh in forum Authoring (DVD)Replies: 2Last Post: 12th Apr 2010, 09:56 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Opening crawl of star wars a new hope shows mutiple languages
By tschroeder250 in forum DVD RippingReplies: 5Last Post: 21st Dec 2008, 23:34
