Hi,
I'm using AviDemux to make a x264 movie on a MKV file. So, I cannot understand completely the settings for MPEG-4 AVC codec, for using this MKV to my LG BD370 Blu Ray Player. Any other MKV file (even720p than 1080p) works fine.
How I make this configuration works?
Try find a x264 configuration/preset that you could use. I guess you should try keep it at h264/avc level 4.1. Check http://avidemux.org/admForum/viewtopic.php?id=4533
Each device is different , and some have quirks of particular settings to avoid or include
The profiles you download in megui are generic but should work for most of the targetted devices that are named in the profile
If you want more comprehensive information on blu-ray look here. (blu-ray imposes many restrictions and a blu-ray compatible encode should work on most devices that support avc high profile)
http://forum.doom9.org/showthread.php?t=154533 -
Another option is to encode to avchd. Try multiavchd.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 14:58 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 22:04 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 12:48
