Bit of an odd request, here - can anyone reccommend a quick, simple procedure for creating an .avi file that doesn't need to be anything more than five seconds of blank space, to be used as a placeholder between other .avi files?? I tried to make one using a gif-to-avi converter, and it seemed to work, but then the resultant file wouldn't play on the DVD player. Then I tried to make one using vdownloader, but it was so big I ran out of space on the CD.
Advice - or just a download location for such a file, if it already exists - would be greatly appreciated.
You can't have an empty avi. It would have to be 5 seconds of black video with zero volume audio. You can do this in virtualdub by starting with a black jpg file
Read my blog here.
Black and silent is what I was looking for, guns1inger - and Case, thank you very much for providing it!
I originally tried to use virtualdub by capturing a black frame from an existing video and copying that frame until I had something long enough, but I must have messed up somehow because the file size was disproportionally large.
Thanks again for both of your help
If you don't set a compression codec (and configure it correctly) then virtualdub produces uncompressed video which is, as you discovered, quite big.
Read my blog here.
Sorry if already posted about converting .avi to Blank DVD's
By tcory in forum Video ConversionReplies: 3Last Post: 26th Jul 2011, 17:30 -
Blank video when converting MP4 to AVI DivX
By vidnov in forum ffmpegX general discussionReplies: 16Last Post: 12th Mar 2010, 17:45 -
creating dummy avi
By deadrats in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 21:17 -
Blank video in avi file
By skaleton in forum EditingReplies: 9Last Post: 16th Apr 2008, 16:42 -
A few questions on creating AVI's
By Sober in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2007, 05:09
