Hi guys,
Here is my problem. I want to rip a DVD Karaoke which has two channels (one Ch only with melody and the other melody+vocal)
I have tried many software ripping it to play on VCD Karaoke player ( a really good one but it doesnt support DVD).
All of them can only extract (rip) only one channel and I cant switch it on the fly between melody and with vocal.
Can the VOB2MPG Pro do it please? Or can anyone suggest any other software if VOB2MPG Pro dos not please?
You kind advice would be very much appreciated, I have been looking for solution for days and still have no idea
Thank you very much in advance for all the kind support and suggestion. Good luck![]()
I think you have to convert the two audio tracks to one audio track with separated left and right audio channels. I doubt that any tool will do this automatically for you so you have to use demux the audio tracks from the dvd with for example pgcdemux, use a audio tool like audacity to fix the audio, last add this new audio to your vcd encoder/authoring appp.....lots of work...get a cheap dvd player...
VOB2MPG and SVCD2DVD does not make any VCDS. -
Ripping dual audio tracks Karaoke DVD
By Longhorn1955 in forum Newbie / General discussionsReplies: 3Last Post: 8th Dec 2011, 00:14 -
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 10:02 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 16:53 -
karaoke VCD to DVD
By biemew in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2008, 06:16
