so i copied a dvd9 to my hd. i try burning them on verbatims with nero and even tried with magiciso.. but no matter what when playing the dvd in a dvd player it skips. and when u push on the remote next chapter it hangs. on the pc it plays just fine..can anyone tell me step by step how to burn dvd9 the right way? and what could be causing these errors? i even used other brands dual layer dvd's didnt helped.
You have to start with good media. I recommend Verbatim brand double layer disks. If your burner is fairly new (within the last three or four years or so) you can use either the Verbatim 8x or 2.4x-6x varieties. If your burner is slightly older, use the slower speed disks.
The next step is to use ImgBurn for burning dvd-video to a double layer disk. It will set the layer break correctly for you. ImgBurn is free to download and use. Here is a guide for burning dvd video files to a double layer disk with ImgBurn: http://forum.imgburn.com/index.php?showtopic=1780
I normally burn DL media at 4x. -
^Yes. I know. I still recommend Verbatim DL media for this. And if the original poster is using a very old burner I still recommend using the slower speed disks. MKM001 mid code. If angles was in the US, he could also try Falcon brand, but I'm not sure they are available in the Netherlands.
If the rip was done properly, there should be no problem burning with ImgBurn from file format. I would use AnyDVD to break encryption and rip to an ISO personally, but the other way works ok too. -
thanks so much for replying guys..but unfortunatly what you are saying i have done.. 1 verbatim dvd9 dual layer discs. 2 set the layer break in that program.. but still those errors when playing it on dvd player. i used dvd decriptor to rip it to hdd..but the same errors happen with burning downloaded dvd9.. i really dont know what to do anymore. true im using an old burner.. my pc is like 5 years old.. ps: sorry if my english is not correct..
DVDDecrypter is out of date and has not been updated since 2005. Use DVDFabDecrypter to rip to your hard drive.
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
Burning 10 full length vids into a DVD9
By maggot6sic6 in forum Newbie / General discussionsReplies: 18Last Post: 24th May 2008, 00:06 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 19:41 -
burning error using imgburn DVD9
By mvp in forum Newbie / General discussionsReplies: 6Last Post: 4th Nov 2007, 01:04
