Hi,
I own a Panasonic GF1 camera and record AVCHD lite movies with it. They use an MTS format/container. I want to be able to play them with my Samsung TV using Samsung's streaming software, but that software doesn't accept .mts files. It does accept .mkv though, and I know that the movie format (AVC and AC3) can be played on my TV.
So all that's left is to convert the MTS to MKV without re-encoding (e.g. keeping AVC video and AC3 audio). I've tried searching for a tool to do this. Does anyone know of a solution?
Thanks!!
	mkvtoolnix doesn't support reading from transport streams , so you could use haali muxer (comes with haali media splitter, "gdsmux") , and then mkvtoolnix to add in the audio . If you need to you could demux the audio from the .mts with tsmuxer to add in later with mkvtoolnix. eac3to would be another option that should be able to do this
	Thanks Tony, that's what I've tried and it works! Fast and simple. Unfortunately, the video on the TV is choppy but I think that has to do with the TV's decoding software. It seems like I can't get away from re-encoding, either that or I figure out how to stream the vids to my Samsung Blu-ray player (that one should be able to play .MTS - I hope)
	Yes, I've noticed that. I changed it to 29.97 based on the following MediaInfo output (tried 59.94 but that made the video play at 2x speed):
 Frame mode : Frame doubling
 Duration : 44s 511ms
 Bit rate : 7 900 Kbps
 Width : 1 280 pixels
 Height : 720 pixels
 Display aspect ratio : 16:9
 Frame rate : 29.970 fps
 Original frame rate : 59.940 fps
	If I demux an MTS file using this tsMuxeR application and click the checkbox marked "Change Level" and specify 3.2 down from 4.2 for compatibility with a hardware player, is this conversion lossless in the eventual output?
 I've tried it, and sure enough MediaInfo reports the output as having level 3.2 compression instead of the original source level 4.2, but it still doesn't play on my hardware player which reports "Video File Not Supported". The demuxing process was incredibly fast at only 8 seconds. Not enough time for a complete re-encode to another level, so I'm suspicious about what's going on. Anyone know for sure? Does it just change the information in headers that MediaInfo reads whilst not touching the actual compression level?
  mts to MKV or aviBy vblanche in forum Video ConversionReplies: 9Last Post: 17th Mar 2012, 14:17
  Legria M306 MTS to MKV conversion helpBy zack28 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 30th May 2011, 13:22
  Trouble balancing quality vs size in MKV and MTS conversions.By Omid in forum Video ConversionReplies: 4Last Post: 17th Mar 2011, 19:47
  Can do I de and remux MTS files from Panny Lumix camera to TS/mkv, etc?By Emanef in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Jan 2010, 13:11
  Convert .MKV to .MTS (AVCHD) for use in BD 35 Blu Ray playerBy NirvClub in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 16:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
