Results 1 to 15 of 15
  1. I have Sorenson Squeeze and TMPEGEnc 4.0 Express, but I can't seem to find a way to encode a video in h.264 within a mpeg2-ts container. I would love to do it in mp4, but the client requires the file in mpeg2-transport stream
    Is there a software solution? Please help
  2. You could encode it into .mp4 container then rewrap it with tsmuxer into a transport stream
    Most software will have blu-ray or avchd presets, they will usually be encoded and wrapped with transport stream as well
    I would check with your client to see if there are any other specific restrictions
  3. Originally Posted by poisondeathray View Post
    I tried tsmuxer. I exported a video only mp4 and aac only. When I join them and export I get an error
    MP4/MOV error: Invalid H.264/AVC frame at position 1636278
    when I try to mux the video only mp4 i get this error
  4. you probably have errors in your stream. I would use a better encoder anyway . Export a lossless avi, and use multiavchd to encode
  5. Originally Posted by poisondeathray View Post
    I am getting more errors through multiavchd. I can't export in lossless AVI again as the media is already offline on my timelines. So I have avid quicktimes that i need to transcode.
    Any other options?
  6. Well if your input stream has errors or is corrupted, you should fix them . If both programs indictate errors, it's likely with your material . If that's not an option , you're probably screwed.
    What kind of media do you have right now ? use mediainfo (view=>text) .
    And there is no way to going back to the original project ?
  7. my ffmpeg video converter stops working when i run multiavchd.
  8. General
    Complete name : HDFINALVERS.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 741 MiB
    Duration : 40s 40ms
    Overall bit rate : 155 Mbps
    Encoded date : UTC 2010-07-12 16:32:37
    Tagged date : UTC 2010-07-12 16:33:45
    Writing library : Apple QuickTime
    Video
    Format : VC-3
    Codec ID : AVdn
    Codec ID/Info : Avid
    Codec ID/Hint : DNxHD
    Duration : 40s 40ms
    Bit rate mode : Variable
    Bit rate : 154 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bits/(Pixel*Frame) : 2.473
    Stream size : 734 MiB (99%)
    Language : English
    Encoded date : UTC 2010-07-12 16:32:38
    Audio
    Format : PCM
    Format settings, Endianness : Big
    Format settings, Sign : Signed
    Codec ID : twos
    Duration : 40s 40ms
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 7.33 MiB (1%)
    Language : English
    Menu
    Duration : 40s 40ms
    Language : English
    Encoded date : UTC 2010-07-12 16:33:44
    Stream size : 4
    this is the media info of the file that I need to convert
  9. you need quicktime installed and dnxhd installed , and you could convert it though avisynth & multiavchd , assuming the stream is error free. I've worked with dnxhd without any problems
    an alternative is to convert it to h.264 using quicktime then tsmuxer to re-wrap into transport stream
    you can't re-wrap dnxhd into transport stream , because it's not compatible (if that was what you tried before - you weren't very clear).
    newer builds of ffmpeg should be able to handle it as well , what do you mean ffmpeg stops working ?
    this really suggests you have stream errors
  10. Banned
    Freedonia
    If the client requires an MPEG-2 TS file, I've got a feeling that they probably want MPEG-2 video in it as well and not this bastardized H.264 in an MPEG-2 TS wrapper. Maybe I'm wrong, but I'm really getting the feeling that vid2me is trying to give them NOT what they want, but what is convenient for him. If I am right, you do understand that not giving the customer what they really need may be a great way to ensure that you lose their business forever, right? I work in IT and sometimes I have to deal with customers when certain issues between us and them need debugging and I know that customers often do a terrible job of describing what they really want, but man, I've got a bad feeling here that what vid2me is trying to do is not at all what they are looking for. If you could lose your job if you get this wrong, I urge you to clarify just exactly what the customer expects to receive rather than just assuming that what you propose will be OK.
  11. Originally Posted by jman98 View Post
    They have explicitly stated that they want h.264 inside an mpeg2-ts file. I would have loved to provide them h.262 within m2ts or h.264 within mp4, but what they want might only be realistically possible through a dedicated hardware solution.
    I was quite perplexed when they asked for mpeg2-ts with an h264 compression....
  12. Originally Posted by jman98 View Post
    h.264 in transport stream is very common format. Most blu-ray titles use this compression ( a few use MPEG2 or VC1). Broadcast in Europe, BBC, Italy all use h.264 transport streams. Just because America still uses depreciated MPEG2 , doesn't mean the rest of the world has to
    Guys this isn't something obscure. AVCHD is h264 video in a MPEG2 transport stream. Just about every consumer HD camcorder uses it. Think AVCHD camcorders .
    Don't get hung up on the term "MPEG2 transport stream" . It's just a transport stream. It' s just a container to hold things. .m2ts IS a MPEG2 transport stream , just as .ts, .mts are as well.
  13. Originally Posted by poisondeathray View Post
    I get ffmpeg not responding error in the middle of the transcode
  14. So that's 3 different programs that suggest the stream is corrupted. Let me guess it aborted near the same location as the other programs spit out errors ?
    Can you play/scrub though that stream over that point ?
    You could try to convert to h.264 in quicktime pro, then re-wrap in tsmuxer - this is hoping QT doesn't "barf" on the same error at the same spot
    I suspect you have to go back to the original project and re-export an error free stream
    I hope that any confusion over "mpeg2 transport stream" is cleared up ?
  15. woooohoooo, it finally worked. I tried another file and it worked like a charm. First mpeg4 avc/h264 encoding through TMPGEnc and then tsmuxer to output m2ts.
    Checked the specs through media info of the outputted file and everything is just dandy. Thanks a bunch
