heyy all,
i hope someone can guide me help me...
what i have is an .flv file, mediainfo reports it as avc codec. 4:3
i want to convert the .flv to (doesnt really matters which format) but preferably to HQ iPod 16:9..
1. i cant open the avc h264 flv in virtualdub.. how do i do that?
2. what is the best way to convert it from 4:3 to 16:9 (resolution i think then should be 640x360?)
3. most programs i tried to convert with, the resulting file video allways is a little bit blocky and got noise.. how can i avoid that?
4. i heart that cyberlinks mediaespresso 6 is an program which got true theather filter, will that avoid the blocky noise?
i know im asking a lot of questions.. but i realllyyyy want to convert it to an HQ video. (and yes the flv is reasonable quality, doesnt got grainy blocky noise..)
thanks in advance..
PS: what i have installed till so far is only K-lite codec pack.
1) dump the tiny blue font.
2)maybe then it will be legible.
3)you can't convert from 4:3 to 16x9 without cutting off the top and bottom or adding black bars on the sides.
4)give xmediarecode a try.--
4:3 to 16:9 with black bars on the side only possible? i guess the black bars will be on the left and right. thats not xacly what i want..hmm guess ill leave 4:3 in 4:3 and forget about the 16:9. and cutting off from the top and bottom is nope.
the only other choice to go from 4:3 to 16x9 is to stretch the horizontal and make everything short and fat.
Flv with avc and aac coding.How do i join them anyway?
By noeway in forum EditingReplies: 1Last Post: 19th Apr 2012, 04:13 -
How to convert mp4 to flv in virtualdub?
By sgbd in forum Video ConversionReplies: 9Last Post: 2nd Oct 2011, 15:17 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 02:42 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51
