    Aug 2010
    canada
    My dvd burner is writing alot slower than it used to and is constantly failing to write.
    Nero 7 LOG:
    Windows XP 5.1
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 7.10.1.0
    Internal Version: 7, 10, 1, 0
    Recorder: <_NEC DVD_RW ND-3530A> Version: 3.01 - HA 1 TA 1 - 7.10.1.0
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <MagicISO Virtual DVD-ROM >Version: 1.0A - HA 1 TA 2 - 7.10.1.0
    Adapter driver: <SCSI> HA 1
    === Scsi-Device-Map ===
    CdRomPeripheral : SONY DVD-ROM DDU1615 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : _NEC DVD_RW ND-3530A atapi Port 0 ID 1 DMA: On
    DiskPeripheral : ST3500418AS iaStor Port 2 ID 0 DMA: On
    CdRomPeripheral : MagicISOVirtual DVD-ROM 1.0A mcdbus Port 3 ID 0 DMA: Off
    === CDRom-Device-Map ===
    MagicISO Virtual DVD-ROM E: CdRom2
    SONY DVD-ROM DDU1615 F: CdRom0
    _NEC DVD_RW ND-3530A G: CdRom1
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 2047MB (2097151kB)
    Free physical memory: 2047MB (2097151kB)
    Memory in use : 20 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    19.8.2010
    Burn DVD Image
    12:18:38 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    12:18:38 PM #2 IMAGEGEN -10 File ImageGen.cpp, Line 366
    Image was written as DAO.
    DAOI:
    MediaCatalogNumber = ''
    TocType = 0x00
    Finalized = 1
    First/Last Track = 1 / 1
    1: ISRC = ''
    Blocksize = 2048
    TrackMode = 'TRM_DATA_MODE1'
    TrackConfig = 0x00
    First/Last Index = 0 / 1
    Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4608229376
    CUES:
    MTYP: Mediumtype = DVD (old format) (0x1C)
    Image file name: <C:\Documents and Settings\Admin\My Documents\Downloads\Kick_Ass.nrg>
    12:18:38 PM #3 Text 0 File Burncd.cpp, Line 3508
    Turn on Disc-At-Once, using DVD media
    12:18:38 PM #4 Text 0 File DlgWaitCD.cpp, Line 307
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 2250111 (500:01.36, 4394MB)
    12:18:38 PM #5 Text 0 File DlgWaitCD.cpp, Line 319
    Write in overburning mode: NO (enabled: CD)
    12:18:38 PM #6 Text 0 File DlgWaitCD.cpp, Line 2972
    Recorder: _NEC DVD_RW ND-3530A, Media type: DVD+R
    12:18:38 PM #7 Text 0 File DlgWaitCD.cpp, Line 493
    >>> Protocol of DlgWaitCD activities: <<<
    12:18:38 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 793
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (1 - DVD-ROM)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2250112 (2250112) = #2250112/500:1.37
    not relocatable, disc pos for caching/writing not required/not required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2250112 blocks [G: _NEC DVD_RW ND-3530A]
    12:18:38 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 995
    Prepare [G: _NEC DVD_RW ND-3530A] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4608229376, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 2250112 | 0 | 0x00
    2250112 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    12:18:38 PM #10 Text 0 File SCSIPTICommands.cpp, Line 215
    SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
    12:18:38 PM #11 Text 0 File Burncd.cpp, Line 4294
    Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
    12:18:38 PM #12 Phase 24 File dlgbrnst.cpp, Line 1762
    Caching of files started
    12:18:38 PM #13 Text 0 File Burncd.cpp, Line 4413
    Cache writing successful.
    12:18:38 PM #14 Phase 25 File dlgbrnst.cpp, Line 1762
    Caching of files completed
    12:18:38 PM #15 Phase 28 File dlgbrnst.cpp, Line 1762
    Speed measurement started
    12:18:38 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2721
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    12:18:38 PM #17 Text 0 File ThreadedTransfer.cpp, Line 269
    Pipe memory size 590400
    12:19:52 PM #18 Text 0 File WriterStatus.cpp, Line 113
    <G: _NEC DVD_RW ND-3530A> start writing Lead-Out at LBA 2250112 (225580h), length 0 blocks
    12:19:52 PM #19 Phase 29 File dlgbrnst.cpp, Line 1711
    Speed measurement completed: 44.3x (61,254 KB/s)
    12:19:52 PM #20 Phase 36 File dlgbrnst.cpp, Line 1762
    Burn process started at 4x (5,540 KB/s)
    12:19:52 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
    12:19:52 PM #22 SPTI -1066 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x24
    Sense Qual: 0x00
    CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 07
    Buffer x06522080: Len x804
    12:19:52 PM #23 Text 0 File DVDR.cpp, Line 6783
    Drive: _NEC DVD_RW ND-3530A
    Book Type request [NEC]: DVD-ROM, write to RAM
    select Book Type setting from RAM
    Changing the Book Type was finished successfully, return code 0
    12:19:52 PM #24 CDR -1207 File DVDR.cpp, Line 6477
    Book Type automatically set to: DVD-ROM
    12:19:52 PM #25 Text 0 File DVDPlusRW.cpp, Line 675
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    12:19:52 PM #26 Text 0 File ThreadedTransfer.cpp, Line 269
    Pipe memory size 83836800
    12:40:36 PM #27 SPTI -1135 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 11 6E 40 00 00 20 00 00 00
    Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
    Buffer x0bd02a40: Len x10000
    0x00 00 01 BA 45 1F B7 12 35 C5 01 89 C3 F8 00 00
    0x01 E0 07 EC 80 00 00 ED F7 E8 4B F0 1F F9 39 08
    0x4E D9 B2 0B C7 25 CF C4 08 0A 92 8A 4A 3F CB 49
    12:40:36 PM #28 CDR -1135 File Writer.cpp, Line 303
    Write error
    12:40:36 PM #29 SPTI -1135 File SCSIPassThrough.cpp, Line 179
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
    12:40:36 PM #30 SPTI -1176 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1176)
    Sense Code: 0x72
    Sense Qual: 0x03
    CDB Data: 0x5B 01 06 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 03
    12:40:36 PM #31 Text 0 File DVDPlusRW.cpp, Line 935
    EndDAO: Last written address 1142336
    12:40:36 PM #32 Text 0 File DVDR.cpp, Line 6783
    12:40:36 PM #33 CDR -1176 File WriterStatus.cpp, Line 162
    Session fixation error
    12:40:36 PM #34 TRANSFER -24 File WriterStatus.cpp, Line 162
    Could not perform end of Disc-at-once
    12:40:36 PM #35 Phase 38 File dlgbrnst.cpp, Line 1762
    Burn process failed at 4x (5,540 KB/s)
    12:40:36 PM #36 Text 0 File SCSIPTICommands.cpp, Line 261
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    12:40:39 PM #37 Text 0 File Cdrdrv.cpp, Line 11185
    DriveLocker: UnLockVolume completed
    12:40:39 PM #38 Text 0 File SCSIPTICommands.cpp, Line 424
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    Oct 2005
    666th portal
    xx
    Last edited by aedipuss; 19th Aug 2010 at 14:25. Reason: missed what ls's eyes caught
    Don't use Nero. Use ImgBurn.
    Use good discs, not junk. Learn more at http://www.digitalFAQ.com/reviews/dvd-media.htm
    Wait a minute....
    canada
    Did you d/l the image file from the internet?
  5. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    My question too........... .nrg image downloaded?!?
    All sorts of errors.
    Use Imgburn.
    Use better media of course.
    Replace the ide cable!!!
    *** Now that you have read me, do some other things. ***
  6. nrg is a image file created by nero and presumably can only be written by nero, how old is the burner and what media, I would suspect those before Nero, I agree Imgburn is safer for DL discs though.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  7. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    I know that it is a nero image, but that doesnt mean it were created with nero or must be written with it........
    Feb 2004
    Australia
    Means unable to determine media type
    Use better media.
    Should you have two optical drives chained together sharing a mainboard connection ... remove one and retest ... sometimes a drive on the same data channel can interfere especially as they get older.
