What is the best way to convert from .caf files (Actually can be renamed to .aiff) into .m4r so i can use them as ringtones for my iphone?
EDIT:Actually it is said that if you create an .aiff file and rename it to .caf, the iphone will handle it. But i dont see the opposite being true. I extracted some caf off my iphone and renames them to .aiff, but it seems that certain software that handle aiff files cant read this format...
				Results 1 to 14 of 14
	Convert to .m4a (use Switch Audio Converter)
 Rename to .m4r
 Add to iTunes
 Sync with iPhoneLast edited by Case; 19th Aug 2010 at 08:09.
	.m4r is an .m4a renamed? Cause i did convert using this method with different software this morning, and then i copied into ringtone folder with diskaid, but i dont see this sound anywhere...
	Switch Audio Converter doesnt allow for caf files, and the one i used has a 60% limitation since its trial.
 BTW I hate that i have to sync ringtones via itunes. It forces me to delete my music library, since i sync music files with mediamonkey. Now that i synced the ringtones i have to re-apply my music files as well. Damn apple.
	Hi
 If you attach a sample caf file somebody will find a way to convert it.
	Not all .aiff files are created equal. Some software may support only a subset of the specification.
 By comparing a converted .aiff file and the original .caf file in a Hex Editor, I found that the .caf file has a different file header, but the data is the same. The files are not the same, but they are very similar.
 Hmm, the Mac version does.
	I found that audacity handles these files i'm using but i cant seem to find a supported windows binary of ffmpeg so that i can convert to m4r. Does anyone know where i can find a 0.6 ffmpeg zip archive.
 After i convert i also need to test your ringtone playlist theory so that i wont have to erase my music library every time i need to sync ringtones.
 you need a special version of ffmpeg for audacity, you can find the info and links here
 http://manual.audacityteam.org/index.php?title=FAQ:Installation_and_Plug-Ins#installffmpeg
 if you were referring to generic ffmpeg, you can find autobuild binaries here
 http://ffmpeg.arrozcru.org/autobuilds/
	I have seen this pages. This is what i already tried from 1st link and didnt work http://www.gaclrecords.org.uk/FFmpeg_2009_07_20_for_Audacity_on_Windows.zip
 I'll just try one of this autobilds
 EDIT:Tried one, but they dont contain the "avformat-52.dll" that is needed.
	(I will use example.ext to explain the process)
 .caf to m4r: (or caf to m4a)
 change example.caf to example.aiff >drag example.aiff into itunes music section > convert example.aiff using the iTunes AAC encoder - in settings (this will change it to example.m4a) > Drag the newly created file from iTunes to the desktop > Change example.m4a to example.m4r > OR leave example.m4a if you need it as m4a > Finished
 .m4r (or m4a) to .caf:
 rename example.m4r to example.m4a (if already m4a, skip this step) > drag example.m4a into iTunes and convert it to aiff using the iTunes AIFF encoder - in settings (this will change it to example.aiff) > drag example.aiff to the desktop > rename example.aiff to example.caf > OR leave example.aiff if you need it as aiff > Finished
 Tested and works both ways. Hope that helps.
 If you have a wav or mp3 (or other format), convert it to .aiff using audacity audio editor and then follow the instructions above. If you want the .caf into mp3, wav, etc, follow the conversion to .aiff and then convert the .aiff to whatever format using audacity.
  AIFF output optionBy supportpartners in forum ffmpegX general discussionReplies: 1Last Post: 29th Nov 2011, 12:29
  Need something to convert 5.1 AC3 to 5.1 AIFF on Windows!By arminio in forum AudioReplies: 4Last Post: 23rd Nov 2011, 14:54
  AIFF to AC3By danielmak in forum MacReplies: 9Last Post: 13th Feb 2010, 23:31
  AC3 -> AIFF, and AOB -> AIFF for Jaguar 10.5.6?By DeadSirius in forum MacReplies: 4Last Post: 29th Dec 2008, 15:54
  m2v/aiff to FLVBy btmdan in forum MacReplies: 1Last Post: 22nd Aug 2008, 17:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
