  1. First off, yes I've looked at other threads on here about GraphEdit but they aren't helpful for my situation. GraphEdit worked just fine a couple days ago, but now when I open it it'll only show up in the taskbar. It won't open the program window. I'm running Windows 7 Pro 64-bit. Any ideas?
    Nov 2009
    Germany
    Most programs remember last window size and position from last run. And some remember it the wrong way...
    Open Taskmanager, Tab "Applications or Programs" (the most left), Right-click on GraphEdit and choose maximize. This should bring the app up again.
    Cheers, ggtop
    Nov 2009
    Germany
    I'm glad it helped. I know this behaviour from other applications and in Win7 you don't have "Maximize" etc. on the icon in the taskbar...
    ggtop
  4. You can right click on the item in the task bar and select Restore or Maximize. Sometimes a window is completely off the screen (and doesn't support Maximize) so you should right click on the task bar and select Cascade or Tile Windows.
