Hi,
I have a laptop that has a DVD player. I was wondering if there is any software through which I can play VCD. I know I can simply go to the file in the CD and start it manually like that. I was wondering if there is a software that will detect that there is a VCD in the DVD player and automatically play it.
I hope I did not confuse anybody.
Thanks.
Have you just tried it?
With PowerDVD, once you've loaded up the program all you need to do is to insert the VCD and it will start playing (properly -- i.e., with menus).
Even if it doesn't autoplay, all that is required is for you to press the "play" button.
Regards.Michael Tam
w: Morsels of Evidence
Can't play HD videos with Dell laptop
By neworldman in forum ComputerReplies: 2Last Post: 29th Aug 2010, 02:24 -
Play AVCHD disk on laptop
By aboveice in forum Authoring (DVD)Replies: 2Last Post: 1st Jul 2009, 04:34 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
Play movies from laptop to TV
By jhebi in forum Newbie / General discussionsReplies: 9Last Post: 3rd Aug 2007, 14:08
