Essentiallyi think the computer just freezes, I can never tell tho since I'm always away from the computer at the time and the screen has since shut off. Usually goes within 24 hours. The computer is still on but doesn't respond to trackpad/keyboard/any other buttons. Like I said it's 3 years old and don't want to put any real money into it, but could it just be overheating? Hard drive failures? Possibly a fresh install of windows? I'll be getting a new laptop soon enough, but would like this to still be usable. Any help is greatly appreciated. Cheers
If it's out of warranty, ya might wanna google around for a "How To Open and Clean Dust Out of" guide on the model number of your laptop.
I had a Compaq with similar symptoms - that one had a bad power supply board (yours may not - it may just like to hibernate). It finally got to the point I'd have to pull the battery and reboot. In the end it suffered from a host of problems.
....that was the last Compaq that I owned.
I still won't purchase HP products - after they bought Compaq, they knew there were several models of notebooks that had motherboard issues - and wouldn't do a thing to help or support them.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Laptop dvi / hdmi connection to HDTV screen flicker black
By vettesea in forum DVB / IPTVReplies: 0Last Post: 24th Apr 2011, 15:35 -
Black Magic Intensity Shuttle with i7 q740 Laptop
By jonsf in forum Capturing and VCRReplies: 2Last Post: 1st Mar 2011, 09:33 -
Problems connecting a laptop through the SVideo port to a Display VGA input
By jeproca in forum Newbie / General discussionsReplies: 21Last Post: 4th Nov 2010, 10:31 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
Trying to connect laptop dvi outut to HDMI Input
By vettesea in forum DVB / IPTVReplies: 16Last Post: 8th Jun 2008, 16:53
