Hey gang,
Downloaded DVD FLICK https://www.videohelp.com/tools/DVD_Flick onto my HP Desktop (Windows Vista) a while back and love the fact that it seems to be able to burn any files that I feed it onto DVD for home viewing.
In the past month, though, the Audio Sync has been off on every disc that I've burned for my home DVD player... there seems to be a hiccup the moment it starts playing in the video (like a tiny pause, and then the audio is off until I PAUSE and then hit PLAY... then the audio syncs up for a while, until it starts to be off again, so I PAUSE/PLAY to re-sync as many times as I have to to get through the movie.
Anyone have a solution to this, but it a fix to the programme, a theory as to why its happening, or an alternative programme that's freeware?
Thanks!
Doc, AKA dalek7
www.vaughn-media.com -
I used DVD Flick for several years, and for no reason started having the same problem with audio being out of sync..... so I switched to
another program, ConvertX2DVD4, that worked quite well for a while, and then that program gave me audio problems, too.
I think both Flick and Convert X have some sort of audio correction built in, that should be turned off before the conversion process
starts. On many downloaded .avi files, the audio is off by a few milliseconds, and these programs try to correct it automatically.
Also, converting Dolby Digital to AC3 seems to possibly screw things up during conversions....
When DVD Flick started doing what you describe, I tried un-installing and re-installing several different versions, it didn't help at all.....
Recently I just about wasted three DVD-R's, doing .avi conversions of cartoons for my grandson. Had no clue that the audio was
completely off, skipping consistently every few seconds, ruining all the work and time I put into it. I guess the old saying is true...
you get what you pay for.....
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
Audio out of Sync with DVD Flick
By kawyboy in forum Video ConversionReplies: 1Last Post: 5th Apr 2010, 21:51 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
DVD Flick- audio out of sync and subtitles wont show
By gogumakilla in forum Authoring (DVD)Replies: 2Last Post: 4th Nov 2009, 03:09 -
DVD Flick audio sync problem?
By neo*2 in forum Video ConversionReplies: 4Last Post: 6th Sep 2009, 13:51
