    Dec 2009
    Russian Federation
    Hi.
    I have big.mp4 file (h264 video stream). I want to cut out a part from it, but without the full recoding, instead recoding only necessary small part.
    So I've copied (without recode) a part of big.mp4 to ffmpeg_copied.mp4, using ffmpeg tool :
    ffmpeg -i big.mp4 -y -ss 0 -t 3 -vcodec copy -an ffmpeg_copied.mp4
    And recoded another part to ffmpeg_recoded.mp4, using ffmpeg tool :
    ffmpeg -i big.mp4 -y -ss 29 -t 3 -vcodec libx264  -vpre hq -vpre main -b 1200k -coder 0 -refs 6 -an ffmpeg_recoded.mp4
    But when I join ffmpeg_copied.mp4 and ffmpeg_recoded.mp4, using mp4box tool :
    mp4box ffmpeg_copied.mp4 -cat ffmpeg_recoded.mp4 -out copied_recoded.mp4
    I get
    Appending file ffmpeg_recoded.mp4.
    No suitable destination track found - creating new one (type vide)
    error.
    And the resulting file contains the two joining files in different streams. So, the player plays only the first.
    When doing the recode I've chosen the settings to meet the original file's (big.mp4) properties. I've looked this properties using MediaInfo tool. The properties are shown at the end of the post.
    (Joining of two different recoded files or two different copied files goes with no problem.)
    I guess the problem is that I don't see some properties of big.mp4, so I couldn't meet 'em in my encoding settings.
    MediaInfo tool shows only CABAC and ReFrames properties, but no bframes or dct8x8 e.g.
    Could you advise me a way to get all the characteristics of big.mp4, so I would be able to specify 'em in my encoding settings.
    If my guess is wrong, please give me a clue to the source of the problem.
    The files:
    are in the attachment.
    The properties of files:
    big.mp4
            General
            Complete name                    : F:\Utility\u\TPr\mp4Box\forPost\big.mp4
            Format                           : MPEG-4
            Format profile                   : Base Media
            Codec ID                         : isom
            File size                        : 3.76 MiB
            Duration                         : 40s 0ms
            Overall bit rate                 : 789 Kbps
            Encoded date                     : UTC 2010-08-17 18:01:07
            Tagged date                      : UTC 2010-08-17 18:01:07
            Video
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : High@L5.1
            Format settings, CABAC           : No
            Format settings, ReFrames        : 6 frames
            Codec ID                         : avc1
            Codec ID/Info                    : Advanced Video Coding
            Duration                         : 40s 0ms
            Bit rate mode                    : Variable
            Bit rate                         : 815 Kbps
            Maximum bit rate                 : 1 307 Kbps
            Width                            : 480 pixels
            Height                           : 360 pixels
            Display aspect ratio             : 4:3
            Frame rate mode                  : Constant
            Frame rate                       : 25.000 fps
            Resolution                       : 24 bits
            Colorimetry                      : 4:2:0
            Scan type                        : Progressive
            Bits/(Pixel*Frame)               : 0.189
            Stream size                      : 3.76 MiB (100%)
            Encoded date                     : UTC 2010-08-17 17:59:10
            Tagged date                      : UTC 2010-08-17 18:01:08
    ffmpeg_recoded.mp4
            General
            Complete name                    : F:\Utility\u\TPr\mp4Box\forPost\ffmpeg_recoded.mp4
            Format                           : MPEG-4
            Codec ID                         : isom
            File size                        : 334 KiB
            Duration                         : 3s 0ms
            Overall bit rate                 : 912 Kbps
            Writing application              : Lavf52.78.0
            Video
            Format                           : AVC
            Format profile                   : Main@L2.1
            Codec ID                         : avc1
            Duration                         : 3s 0ms
            Bit rate                         : 907 Kbps
            Nominal bit rate                 : 1 200 Kbps
            Width                            : 480 pixels
            Height                           : 360 pixels
            Colorimetry                      : 4:2:0
            Bits/(Pixel*Frame)               : 0.210
            Stream size                      : 332 KiB (99%)
            Writing library                  : x264 core 98 r1629 9d1c441
            Encoding settings                : cabac=0 / ref=6 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1200 / ratetol=3.3 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
  2. I see that the Format Profile is not the same for both file.
    Maybe it's the problem.
  3. You can download the trial versions of either elecard streameye or h264visa for more information on the streams
