Hi, I would like to know which are the best freeware and non-freeware programs for joining clips without re-encoding.
I just know Boilsoft Video Joiner .
It causes some Audio-Video sync problem in the format I use.
Thanks in advance.HTML Code:General Complete name : G:\Descargas\prueba videos viaje\IMAG0041.AVI Format : AVI Format/Info : Audio Video Interleave File size : 3,54MB Duration : 6seg. Overall bit rate : 4 715Kbps Recorded date : 2009-01-02 Writing library : AMBA ICRT : 13:08:03 Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Si Format settings, ReFrames : 4marcos Format settings, GOP : M=3, N=15 Codec ID : H264 Duration : 6seg. Bit rate mode : Variable Bit rate : 4 291Kbps Maximum bit rate : 4 001Kbps Width : 1 280pixeles Height : 720pixeles Display aspect ratio : 16:9 Frame rate : 29,970fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8bits Scan type : Progresivo Bits/(Pixel*Frame) : 0.155 Stream size : 3,23MB (91%) Audio ID : 1 Format : ADPCM Codec ID : 11 Codec ID/Hint : Intel Duration : 6seg. Bit rate mode : Constante Bit rate : 384Kbps Channel(s) : 2canales Sampling rate : 48,0KHz Bit depth : 4bits Stream size : 292Kib (8%) Interleave, duration : 43 ms (1,29fotograma de video)
I don't believe that there is one that can guarantee you a perfect outcome. I use AVI Demux for this type of thing, and have never had an issue with the output, but there are plenty of posts from people with conflicting experiences. Ditto virtualdub. In your case you are asking for trouble because AVC inside an AVI container is a kludge, and many tools don't really know how to handle it properly. If it were me, I would repackage the video into an MP4 container, then try joining the files.
Read my blog here.
Thanks in advance... but I need more help.
I've tried to repackage the video with Mediacoder (copy video and audio selected and MP4 format, multiplexer=auto) and Super (Stream copy in both, MP4 in output container), but in the first one I got an empty file and in the second an error.
I'll try to repackage them with super into MKV (seems to work) and join all with MKVmergeGUI and tell you.
I need some software to batch processing and join more than 500 little files, I know that avidemux is great, but it would be eternal.
Thanks again!!!!Last edited by diodox; 18th Aug 2010 at 07:00. Reason: Errors with MP4
VOB merger/splitter/editor
By altavistasf in forum EditingReplies: 5Last Post: 17th Oct 2010, 21:16 -
Encoding Software
By Laserbelly in forum ComputerReplies: 4Last Post: 11th Oct 2010, 18:20 -
i-media file merger
By GimpGuy2000 in forum EditingReplies: 2Last Post: 4th Dec 2008, 10:56 -
XM-Sirius Merger
By Epicurus8a in forum Off topicReplies: 13Last Post: 17th Jun 2008, 06:19 -
MP3 Merger
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 3Last Post: 10th Jun 2007, 01:53
