I download a lot of tv shows (due to scheduling issues) so I can watch them when convenient. Typically, they are in avi format and I use Pioneer DV-393 decks (ntsc & pal & divx) to play back on standard tvs. As of the last few months, most of the videos play back audio that is (my best guess) Dolby encoded. So what I hear is highly compressed audio and the background sounds tend to overwhelm the dialog. I'm assuming that the Pioneer decks don't understand the audio format and just play it raw.
My question: is there any way to decode whatever compression (again, probably Dolby) and rebuild the avi with a raw wav or mp3 audio that is decoded for simple play back?
Thanks!
Most downloaded XviD/DivX TV shows use MP3 audio already. However, you could run a file through GSpot or MediaInfo to find out for sure what kind of audio it is. Maybe there's something wrong with your player or audio system, or they're not set up properly. Does it sound any better when played on the computer or on a different standalone?
To answer your question, yes, it's a simple matter to extract the audio and reencode it however you like.
Problem listening super audio CD
By 1234567 in forum AudioReplies: 17Last Post: 22nd Nov 2011, 18:09 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 19:05 -
Adding audio as background music whilst listening to the main sound
By Mrwoo1234 in forum AudioReplies: 3Last Post: 29th Dec 2007, 09:30 -
How do I write new subtitles to a DVD (by listening!)
By cemman in forum SubtitleReplies: 2Last Post: 17th May 2007, 19:25
