  1. I'm attempting to burn a Blu-Ray disc in Encore CS4. On the build screen, under Disc Info, it says 17.56 GB used, 7.44 GB free. When I click 'build', it displays 'Written: 0.00 of 17.56GB' while importing whatever it needs to, but once it starts actually writing the ISO, the 17.56 becomes something over 28GB, which obviously won't fit on a disc.
    Where's this extra data coming from, and how do I get rid of it?
    Reconverts the video?
  3. The video file has already been transcoded, and comes in at just over 17 GB, so it's not transcoding it to a bigger filesize, if that's what you're getting at.
  4. Member kmnorya's Avatar
    Sep 2010
    Sydney
    I got the problem in reverse, i set the bitrate for a 45 min SD video(MP4) using PAL SD Max Quality to about 1GB but after transcoding it became 2.5GB? Why is this happening? I was trying to put 20-25 video in one bluray discs and play back in regular bluray player with custom menu, how can I do that?
