    Mar 2008
    Hi,
    I have an Asus M2N68-AM SE2 mobo. Windows XP SP3, Bought a camcorder, dv firewire. When, I open any video editing programs, Sony Vegas, WMM, etc.... cam is not detected. Using onboard firewire.
    Do I need to purchase port firewire card ? Any assistance would be appreciated.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by Illusionist View Post
    Asus M2N68-AM SE2 mobo...
    Did you install the IEEE-1394 driver from the ASUS CD?
    Better to download the latest version.
    Try WinDV for DV stream to DV-AVI file.
    http://www.kiva.org/about
    Mar 2008
    Hi Ed,
    Thanks for reply. No firewire driver on Asus cd. Went to hardware, manual setup, dialog box states 1394 controller has no drivers.
    Did research and cannot find drivers for Asus firewire port. Nor could I find anything from Microsoft. Apparently should work just plug/play. Well, I'll purchase a firewire card to see, if that resolves the issue.
    Mar 2002
    Maybe your problem is the same as mine. The onboard firewire port was working since day one when I got my MSI motherboard. One day it just stopped working so I had to use my spare firewire card.
    Mar 2008
    Hi Joy,
    Thanks for reply. Beginning to learn, Asus firewire port is not optimal. Hopefully, firewire card, resolves issue, will update progress.
    May 2001
    New Zealand
    Hope it's not the camcorder. This happened to me earlier this year with a Canon HV20. The Firewire port was DOA.
  7. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    You always should be careful when connecting firewire devices to a PC.
    Specially the firewire with sony camcorders are prone to get damaged when conected to a working PC.
    I personally turn off my PC and camcorder when connecting everything.
    Mar 2008
    Okay, just figured it out. My mobo does not have a 1394 port, my Antec case does. Cannot connect case 1394 port to mobo. Will be purchasing firewire card. It's been a long night. I need to get some sleep, Lol !! Thanks, everyone for help.
