I have a lg bd570 which can play varoius types of media throgh a usb hard drive and would like to know the best and easy way to do so?
Results 1 to 12 of 12
Can your drive transfer the decrypted Blu-ray to a computer? That appears to be a standalone Blu-ray player.
yes my drive can first to my hard drive then i want to make a quick mkv hd for my usb drive that is connected to my dvd player. i tried fab but it doesnt work for mkv.
red, I believe that he was planning on playing it on his DLNA complaint device, via HDD. Hannibal, might I inquire as to what issue you were having with MakeMKV? I have used the method I suggested and never had an issue. The method I mentioned was to get the MKV file and then Handbreak to shrink the file. It may be possible to use DVDFabDecrypter to ISO and then import it into handbreak, but cannot admit to having tried it.
make mkv copys the whole movie and wastes time where as i only want the main movie not trailers or extras.
its not free and already have any dvd and anydvd. But i will give hanbrake a shot, aslong it keeps original audio and same quality i would be happy.
It's never costed me anything http://www.makemkv.com/ it just has to be updated every so often.
You have to buy it if you want to convert or stream Blu-Ray discs.
From http://www.makemkv.com/buy/
MakeMKV contains both freeware and shareware functionality. You may use MakeMKV to convert or stream DVD and AVCHD discs for free, as much as you want. Converting or streaming Blu-ray discs is shareware functionality. You can use shareware functionality for free during 30-days trial period. If you like MakeMKV and you want to use it after your 30-days trial version expires, you need to purchase a registration key.If cameras add ten pounds, why would people want to eat them? -
i keep having problems where the audio keeps going from dts -dolby pro logic so i get no sound? I am keeping thr video from source as well as the audio which is dts-hd. i tried pavtube and the only audio u can select is ac3 5.1 and then it works, but with the dtshd i get video but problems with the audio? tried dvd fab mkv and blurip.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Apr 2010, 00:07
