I may have someone who might be willing to build a computer for me in order to adequately run Premiere Pro CS5 which I'll have to upgrade to as well.
First, I'll need to get a determination/recommendations as to specifically what hardware is needed and to acquire a comprehensive component/parts list in detail with the specs.
Any suggestions as to where to purchase those parts at a reasonable cost would be valuable as well.
It would be appreciated to learn what your system configuration is and what your thoughts are as to its effectiveness and speed. I would like to know what to do, avoid or any other pertinent & helpfull information.
All tips, pointers on the web in regards to this subject are welcome as I want to do it right the first time.
Somehow I'm thinking a pre-made mail order system from the internet such as Dell is not the right path to travel.
Thanks so much as this will be a big adventure.
	newegg is about as cheap as a reliable supplier gets.
 core i7
 x58 motherboard
 8 gigs ram
 GeForce GTX 285 or quadro
 4 f3 spinpoint 1tb drives
 should be a starting point for you.--
	What is the 4th hard drive for and what sort of a case do I need?
 1) OS
 2) Source
 3) Destination
 4th? You got me sir!
	Co-incidently a few weeks ago I got a 1 tb spinpoint and they are actually quite decent.
	4) scratch drive - program temp files
 yeah for a 7200rpm the are quite speedy and quiet
 [edit] i don't know if it actually speeds things up, i have never tested my rendering machines with and without to compare, but i like to think so -- --
	Can't have too much storage space. I have...
 1 - 160 GB boot drive
 1 - 500 GB capture drive
 3 - 1 TB storage drives
 1 - 500 GB Temp drive that connects to the top of my case
 1 - 1 TB My Book (e-SATA, firewire, USB)
 1 - external HHD enclosure (e-SATA, firewire, USB) for various HDDs
 2 - 8 GB thumbdrives
 I have a CM 690 II Advanced case. I saw a couple of Lian Li cases that looked OK but went for the CM 690 II because they had it at my local Fry's Electronics and it had everything I was looking for (except no front firewire port). I would recommend any of the HAF Cooler Master cases also.
	What processor in the i7 family is suitable? It doesn't have to be the absolute fastest.
 What's ideal? Acceptable? Preferable?
 What strength/wattage should the case power supply be?
  Just built my computer..any tips?By NaHLiJ in forum ComputerReplies: 25Last Post: 25th Oct 2011, 11:54
  Computer Guys Braggin' Time: What have you built that AIN'T a computer?By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 16:19
  How to run 2 computers off of one set of computer speakers?By Denvers Dawgs in forum ComputerReplies: 14Last Post: 7th Feb 2010, 10:54
  Has Anyone Built an I5 Processor Computer?By Soopafresh in forum ComputerReplies: 4Last Post: 5th Dec 2009, 16:46
  I can not run some VCDs on My Computer. Need some Assistance.By wapw in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jul 2007, 15:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
