Hi
I'm trying to add .srt subtitles to an NTSC dvd using DVD-Lab pro. As usual I create a subtitle stream, but all the timings in the resulting subtitles are messed up.
In Media Player Classic I can turn on the newly created subtitles and also add the original .srt subtitles at the same time. The latter is fine while the former is all messed up.
I actually remembered reading about this issue like a year ago and it has something to do with converting time marks into NTSC frames.
Also tried txt2sup + muxman, same result. Is there any way around this thing?
Ok, I did find a way out. If someone has the same problem, the latest txt2sup and muxman work fine. Well, almost fine. The subtitles got shifted somehow, so I did the opposite shift in Subtitle Workshop. Then it turned out that the subtitles' stream goes a little faster the video stream (adds up to about 4 seconds in 1.5 hours). So again, had to adjust the .srt file in Subtitle Workshop and mux the DVD again.
Good luck. -
If they're playing faster and about 4 seconds off by the end of a 90 minute movie, then somewhere along the line your subs got converted to non-drop frame timing (30fps), from the original drop frame timing (29.97fps). Check around in whatever you're using to create the subs. Except for Muxman, I don't use any of the programs you mentioned, and I create a lot of subs but never have this particular problem.
NTSC DV from Final Cut Pro to NTSC DVD Problems
By Killer3737 in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:25 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 01:39 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53 -
dvd-lab issue, needs to be solved desperately
By cL0N31 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 10:49 -
DVD Lab Pro - 2 cells issue
By GangstaRap in forum Authoring (DVD)Replies: 4Last Post: 24th May 2007, 09:44
