got a slight prob with usb mass storgae devices using windows 7. Basically whenever i copy to the device like my flash stick.....or amny flash stick! It just stays on the x amount of time remaining and does nothing. Have waited hours and still same amounr of time remaining. no issues in device manager either. Ne1 got any ideas?
Cheers!
1. Try transferring only a few files at a time.
2. Realize that some USB memory sticks die quickly. -
Some USB sticks are better than others. If you'd like a recommendation, I've been buying Patriot brand as I find them reliable. Even the best manufacturers do sometimes produce sticks that fail and have to be replaced. You could also try reformatting the stick and see if that helps.
1: Right click on the USB drive and select properties
2: Select the Hardware tab
3: Under All Disk Drives, highlight your USB drive and select Properties
4: Select the Policies tab and select Optimize for performance.
5 Press OK twice
Should solve the mystery ... and always use the safe removal icon or risk data corruption. -
Get a short usb lead .. it can prevent damage to both your USb device and your Usb computer slot. However your Usb stick/device sounds like its either getting bad connects or has reached End of life, remember flash memory has limited read/write cycles and some are very short lifespans. Its probably just a bad Usb connection, try jiggling the thing around, or altering the "in" part with a pair of pliers to maintain contact in the slot. Try a different Usb lead if its a disc drive.
Power ! to the people! who put usb powered devices into their computers! a usb powered device may not be getting enough juice eg a 2.5 inch disc drive, try in others computers to ascertain continued viabilityCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
playing film from usb stick on tv
By dougvcd in forum Newbie / General discussionsReplies: 11Last Post: 19th Aug 2010, 11:43 -
Only SOME of the jpg:s on my USB stick can be displayed by the TV
By anla in forum DVB / IPTVReplies: 3Last Post: 1st Nov 2009, 05:44 -
USB stick won't fit in printer
By csaag in forum ComputerReplies: 4Last Post: 25th Aug 2009, 20:54 -
USB stick no longer recognised....can it be saved?
By Rudyard in forum ComputerReplies: 6Last Post: 9th Apr 2009, 18:53 -
USB memory stick recommendation...
By retroborg in forum ComputerReplies: 5Last Post: 12th Sep 2007, 06:55
