i want to archive my finished videos on a cd to free up space on my hd. what's the best way to do this?
also, should i burn the whole project? or just the finished product?
Results 1 to 10 of 10
there a several ways to put video to cd and the best way depends on your needs.
as to burning the whole project, you have to keep all the footage for it to be worth anything... do you really think you'll reuse them? if so than save it elsewise just save the final video. -
true...i probably won't use the footage...
so...umm...with what way should i put the final product onto cd?
thanx for your help -
excoelis, I just purchased some extra DV tapes and exported my finished project back to DV, seems to be about the best idea I could come up with until I can get that new DVD-RW.
well i kinda agree with excoelis except that when i do video they are usually small enough to fit on a normal cd as a minidvd. but transfering back to mini dv is a good idea as long as you make sure you don't put it neer anywhere where there might be magnetic fields (speakers, computers large electronic in general). My mini dvds are very high quality (2 pass vbr 8000-5500-3500(iput maximum bitrate at 8000 cause any higher and you lose all but the most powerfull computers )
anyone wanna send a DVD-RW drive my way?
mini dv is cool too...too bad i don't have a mini dv camera and tapes...
well...i have a 7 minute project and i wanna just be able to put that onto cd to keep. i've tried just exporting it with all it's fixings into .avi format. bad idea...gig and a half...
now i just want to keep as much quality as i can...and get it to at least less than 700MB...
so...please...any ideas? -
make a mini dvd (or at least dvd bitrate mpeg) you'll probably have a file about 250-300meg so it'll fit on a cd with high quality.
Originally Posted by resnullius
check out frameserving from premiere to tmpgenc here http://www.videotools.net/uk/guide_premiere_tmpgenc.php
load dvd template in tmpegenc, use a 2 pass vbr(longer but worth it(in my opinion), i use 3500 lowest, 5500 average, 8500 highest) or 8000kbps cbr.
Ready Made Templates/Projects for Video Editing SW
By ozab in forum EditingReplies: 5Last Post: 4th Nov 2012, 00:12 -
Workflow for collaborating on video projects from a distance
By davidcom in forum EditingReplies: 5Last Post: 5th Aug 2011, 21:45 -
Premiere Pro - New Projects Freeze
By Outline in forum EditingReplies: 3Last Post: 27th Mar 2010, 19:51 -
How to Encode Womble Mpeg Video Wizard projects with HCenc
By tmw in forum User guidesReplies: 18Last Post: 10th Jul 2009, 14:49 -
Asking advice about HARDWARE for VHS VIDEO conversion projects
By perniente in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2007, 18:05
