sometimes it works fine, sometimes it doesn't. all i get half the time is a 'bye' (says that on the dvd recorder) and i have to switch it off and on a few times (at the mains). i can only access the play menu if i press play on the remote. it says 'exit l' on the dvd recorder and i can't do nothing but press play.
do these companies actually test these before they sell them?
You return it and get another.
Most stores will replace items in the first 30 days. Beyond that it needs to go to a factory warranty service center.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Copying DVD movies with a Sony VRD-MC6 Multi-Function DVD Recorder.. help?
By madeyeX in forum DVD RippingReplies: 14Last Post: 17th Dec 2014, 21:36 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 06:59 -
Panasonic DMRES45V DVD remote doesn't work correctly
By cep8719 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2008, 12:00 -
FLVtool2 doesn't install correctly
By chaosmoon in forum ffmpegX general discussionReplies: 5Last Post: 12th Feb 2008, 20:25 -
DVD recorder that doesn't require remote
By Knightmessenger in forum DVD & Blu-ray RecordersReplies: 13Last Post: 27th Nov 2007, 00:51
